Install supplementary coordinate system data
Some geographic transformations (for example, NTv2, GEOCON, and NADCON5) and vertical transformations based on geoids, quasi-geoids, or other conversion grids (for example, EGM and VERTCON) require files that are not installed with ArcGIS Reality Studio. You can download and install these files with the ArcGIS Coordinate Systems Data software component from My Esri.
Install ArcGIS Coordinate Systems Data
The ArcGIS Coordinate Systems Data component is required if you perform geographic or vertical transformations.
Follow the steps below to install ArcGIS Coordinate Systems Data.
Download the ArcGIS Coordinate Systems Data (Windows) installation from My Esri.
The download is available in the Downloads > ArcGIS Enterprise (Windows) section of My Esri. The downloaded file name is
ArcGIS_Coordinate_Systems_Data_Windows_<release_part#>.Place the ArcGIS Coordinate Systems Data installation file on each machine where ArcGIS Reality Studio is installed.
Browse to the location where you placed the ArcGIS Coordinate Systems Data file, and double-click it to start the installation process.
Accept the destination folder to which files are extracted and placed in a folder named CoordinateSystemsData, or click Browse to select a different destination.
The default destination folder for the CoordinateSystemsData folder and files is
<System Drive>\Users\<username>\Documents\ArcGIS <version>.Accept the destination folder to which files are extracted, or click Browse to select a different destination.
The default destination folder for the files is
<System Drive>\Users\<username>\Documents\ArcGIS <version>\CoordinateSystemsDatawhen you extract ArcGIS Coordinate Systems Data and<System Drive>\Users\<username>\Documents\ArcGIS Pro <version>\ProCoordinateSystemsDatawhen you extract ArcGIS Coordinate Systems Data for ArcGIS Pro Per User Install.Click Next.
A message indicates when the files have been successfully extracted, and the Launch the setup program check box is checked by default.
To install the software later, uncheck the Launch the setup program check box and click Close. When you're ready to install, browse to the folder in the destination you specified in the previous step. If you downloaded and extracted ArcGIS Coordinate Systems Data, open the SetupFiles folder, and double-click
CSD.msi. If you downloaded and extracted ArcGIS Coordinate Systems Data for ArcGIS Pro Per User Install, double-clickProCoordinateSystemsData.msi.When you're ready to install, browse to the CoordinateSystemsData folder in the destination you specified in the previous step, and double-clickSetup.exe.Click Close.
In the first window of the setup wizard, click Next.
Review the license agreement and choose an option:
If you agree to the terms, click the option to accept the agreement and click Next.
If you do not agree to the terms, click Cancel to exit the installation.
Optionally, in the Select Features window, choose the grids to exclude from the installation. Click the corresponding button in the list and choose This feature will not be available.
If you later require a feature you excluded from the original installation, you can modify the installation.
In the same window, accept the default installation folder location, or click Change to specify a different folder.
Ensure you selected one of the features to install to enable the option to change installation folders.
The default installation directory varies depending on which installation you run.
For installations of ArcGIS Coordinate Systems Data, the default location is
<System Drive>\Program Files (x86)\ArcGIS\CoordinateSystemsData.For per user installations, the default location is
<System Drive>\Users\<username>\AppData\Local\Programs\ArcGIS\CoordinateSystemsData.
Click Next.
Click Install.
When the installation is complete, click Finish.
Modify or uninstall ArcGIS Coordinate Systems Data
If you require additional coordinate system grids that you did not install initially, you can modify the ArcGIS Coordinate Systems Data installation to install those missing files. Modifying the installation is only applicable on Windows.
Follow these steps to modify or uninstall the ArcGIS Coordinate Systems Data installation:
Sign in to the machine as a Windows administrator and open the list of installed software.
There are multiple ways to access the list of software installed on Microsoft Windows machines, and how you access the list varies by Windows version. If you are unsure how to access the software list, consult the Microsoft documentation for the version of Windows that you are using.
Select ArcGIS Pro Coordinate Systems Data from the software list.
To uninstall all components, click Uninstall. When prompted to confirm that you want to uninstall, click Yes.
To alter what features are installed, click Modify or Change to access the setup wizard, and proceed with the remaining steps.
Ensure Modify is selected and click Next.
Choose which set of coordinate systems data to add or remove from this machine:
To install all coordinate system data, click the drop-down menu next to Coordinate Systems Data and choose This feature, and all subfeatures, will be installed on local hard drive.
To install an individual coordinate systems dataset, click the drop-down menu next to the dataset and click This feature will be installed on local hard drive.
To remove an individual coordinate systems dataset, click the drop-down menu next to the dataset and click This feature will not be available.
Click Next.
Click Install.
Add third-party transformation grids
For some grid-based geographic and vertical transformations, Reality Studio includes their definitions but does not distribute the grid files due to license restrictions. You must obtain these grid files directly from their third-party provider or government agency. In some cases, you may need to purchase the grid files from their provider.
Once you obtain the grid files you require and you have installed ArcGIS Coordinate Systems Data, create subfolders in the CoordinateSystemsData\pedata folder in the installation location on each Reality Studio machine.
Sort files into folders by transformation type, region, country, and transformation method name. For example, an NTv2 file should be added into a ...\pedata\geographic\<your_region>\<your_country>\ntv2 subfolder and a geoid model can be added to a ...\pedata\vertical\<your_region>\<your_country>\geoid subfolder. For detailed instructions, contact your local distributor.
