Install deep learning libraries for ArcGIS Reality Studio
The deep learning libraries are required to create Gaussian splats products. Gaussian splats generation does not use deep learning algorithms directly. However, some parts of the computation require the same libraries as deep learning. Use Gaussian splats to represent fine structure or natural shape objects such as trees and other vegetation. For example, they can be used to inspect utility assets or infrastructure.
Learn more about the Gaussian splat layer and other 3D layer types
For instructions on how to install deep learning libraries, see the Deep Learning Libraries Installer.
  1. Browse to the location where your installer was downloaded.
  2. Extract the .zip file to a new location.
  3. From the extracted files, run the installer .msi file.
    The installer wizard appears.
  4. Click Next.
  5. On the Welcome to the Deep Learning Libraries for ArcGIS Reality Studio Setup program page, click Next.
  6. On the Master Agreement dialog box, review the license agreement and do one of the following:
    • If you agree to the terms, click the option to accept the agreement and click Next.
    • If you do not agree to the terms, click Cancel to exit the installation.
  7. On the Ready to Install the Program page, click Install.
    The installation starts and displays a progress bar.
  8. Once the installation is finished, click Finish.
You must install Reality Studio before installing the deep learning libraries.
Each version of Reality Studio requires specific versions of the deep learning libraries. When you upgrade Reality Studio, you must install the deep learning libraries that correspond to that version of Reality Studio.
The deep learning libraries must be installed on each processing node in an ArcGIS Reality Studio workspace.
Once the installation is successful, the libraries are available within ArcGIS Reality Studio and you can generate Gaussian splats.
Back to top
