Reprocess an alignment
To refine the quality of alignment results, you can edit, add, or remove information. Changes in the alignment settings or changed image measurements automatically trigger a reprocessing of the alignment. The following changes to alignment results trigger a reprocessing.
Edit settings in alignment pane
Changed settings for optimization of camera, distortion model parameters, standard deviations of camera sessions or control points will trigger a reprocessing when following these steps:
  1. Change settings in the Alignment pane.
  2. Click Save.
    The Reprocess Alignment warning appears.
  3. Click OK.
    The alignment is updated and automatically resubmitted to the workspace.
Changing the lever arm adjustment setting will trigger a full reset of the alignment.
Change input data
Editing a control point or manual tie point will trigger a reprocessing. This includes adding, modifying, disabling, or removing image measurements or points as well as removing and automatic tie point.
  1. Change point measurements in the image measurement tool.
  2. In the Project Tree pane, click Apply changes on the alignment where you want to apply the changes.
    The Modified Input Warning message is shown.
  3. Click Apply Changes.
