ArcGIS for SharePoint errors, messages, and warnings
The following sections and tables are a log that provides a list of errors, warnings, information, and validation messages you may encounter when using ArcGIS for SharePoint.
Message codes are defined as integers and organized into groups based on categories of service.
Add an ArcGIS layer
The following messages may occur when adding a layer from ArcGIS.
Learn more about ArcGIS layers
Code |
Category |
Title |
Message |
Description |
1001 |
Information |
Web map cannot be added |
There are no operational layers. |
When adding a web map from ArcGIS Online, the source web map must contain operational layers such as a feature service, tile layer, or imagery layer. |
1002 |
Information |
Layer cannot be added |
The coordinate system or tiling scheme must align with the basemap. |
The layer coordinate system of the layer being added must match that of the basemap. Check the layer coordinate system and try again with an aligned layer. |
1003 |
Warning |
Layer cannot be added. |
The layer cannot be added. Check the source item in your organization or contact your administrator. |
1004 |
Error |
Layer failed to fetch. |
Your layer is unable to load on the map. Contact your administrator to troubleshoot. |
1005 |
Information |
Spatial reference incompatible. |
This layer's spatial reference is incompatible with the spatial reference of the basemap. You can either use a different basemap and read the layer, or you can open the item in ArcGIS Online and republish the item with a different coordinate system. Learn more on the Incompatible with current basemap Technical Support page |
1006 |
Error |
The layer failed to copy. |
Remove the layer you want to copy and add again or contact your administrator to check the layer properties in ArcGIS Online. |
1007 |
Information |
No access |
You are currently signed in as |
You do not have adequate permissions to add this content, for example, your user type, role, ArcGIS account, or organization settings do not allow this content, or the content is private or not shareable. Contact your organization administrator for more information. |
1008 |
Information |
The |
Your layer has no features to display on the map. |
1009 |
Information |
Unsupported Version |
The version must be 2.0 or higher. The |
This happens when adding a layer from ArcGIS Online that contains an incompatible web map version. Go to ArcGIS Online, open the web map, and resave to a current version. |
1010 |
Error |
The |
Your layer has been deleted or become inaccessible. Check the source layer or contact your organization administrator to troubleshoot. |
1011 |
Warning |
Query capability disabled |
Check layer edit settings. |
This appears when a layer does not have query capabilities and new geometries are recorded but hidden. To resolve, in the layer settings, change What features can editors see? from Editors can't see any features, even those they add to Editors can see all features. Learn more on the Capability 'Query' is not set on the layer Esri Community page |
1999 |
Warning |
Unexpected error |
Add a data layer
The following messages may occur when adding a data layer from ArcGIS for SharePoint.
Learn more about adding a data layer
Code |
Category |
Title |
Message |
Description |
2001 |
Error |
Adding data failed |
Check your data source and try again. |
Ensure your location data is correct and accessible. |
2002 |
Error |
The selected column doesn't contain any valid JSON geometry. |
When adding Microsoft data as a JSON type, the geometry column must contain an attribute formatted in valid JSON format. Check your source data for import or formatting errors or choose a different attribute. |
2003 |
Information |
No ArcGIS World Geocoder or custom geocoders that support batching are configured |
Contact your organization administrator. |
Go to your portal and configure a geocoder that supports batching. |
2004 |
Warning |
Verify that your data has valid location information. |
Your layer may not contain spatial data. |
2005 |
Error |
Layer failed to copy. |
Remove the layer you want to copy, and add again. |
2006 |
Error |
The file contains invalid JSON. |
JSON format not valid, check the source data for formatting or other errors and try again or select a different attribute. |
2007 |
Error |
Unknown spatial reference |
Check the format of the CRS property in your GeoJSON. |
2008 |
Information |
Large geometries were generalized to avoid memory issues. |
Geometries were simplified to stay within memory limits. |
2009 |
Error |
File size limit of 500 MB exceeded. |
The layer being added exceeds size limits. |
2999 |
Warning |
Unexpected error |
Work with basemaps
The following messages may occur while working with basemaps.
Code |
Category |
Title |
Message |
Description |
3001 |
Information |
Basemap cannot be changed |
The |
Basemap and layer coordinate systems must be the same. Try again. |
3002 |
Warning |
Basemap cannot be loaded |
Check the basemap service or select a different basemap. |
Analyze Buffer/Drive time
The following messages may occur when working with drive time or buffer analysis.
Learn more about Buffer/Drive time analysis
Code |
Category |
Title |
Message |
Description |
4001 |
Information |
The service is not available |
Spatial analysis server is not configured in your portal. Contact your administrator. |
4002 |
Information |
Additional permissions are required |
You need permissions to use Analysis tools. Contact your administrator. |
4003 |
Error |
Buffer analysis failed |
Insufficient credits to perform analysis. |
4004 |
Warning |
Unable to connect to server |
Check your internet connection. |
Internet connection issue. Incomplete buffer. |
4005 |
Error |
The result layer name length should be no more than 98 characters. |
Modify the length of the buffer output layer name to match requirements. |
4006 |
Error |
A result layer already exists with this name |
Use a different name. |
Cannot create buffer/drive time layers with the same name. Rename your result layer. |
4007 |
Error |
The result layer name contains one or more invalid characters (<, >, #, %, :, ", ?, &, +, =, /, *, @, |, or \). |
Check for typos or invalid characters in output name. |
4008 |
Error |
The number of features in the |
This message shows up inline under the input layer of buffer tool. Buffer drive time can only accept up to 1,000 features. |
4009 |
Information |
Location access disabled |
Location services or permissions must be enabled. |
To use your current location as the input for the buffer drive time tool, you must enable access to location services or permissions. This could be blocked by your browser, or your ArcGIS account or your organization does not have the necessary permissions to use location data within the application. |
4010 |
Error |
Contact your administrator or Esri Support. |
4011 |
Error |
There is an error with the feature service. Try again. |
4012 |
Error |
Unable to access geoprocessing server. |
4013 |
Error |
Result layer cannot be found in ArcGIS ArcGIS Online, or ArcGIS Enterprise. |
4999 |
Error |
Unexpected error |
Work with the Information tool
The following messages may occur when working with the Information tool.
Learn more about the Information tool
Code |
Category |
Title |
Message |
Description |
5001 |
Information |
The service is not available. |
The GeoEnrichment Service is not available. Contact your administrator or Esri Support. |
5002 |
Information |
Additional permissions for the GeoEnrichment Service are required. Contact your administrator or Esri Support. |
5003 |
Warning |
The maximum selection for Information tool has been exceeded |
Select a maximum of 100 features. |
When you select features on the map, a displayed infographics card will update to show the demographic information for the areas within the specified distance around the selected feature for a maximum of 100 selected features. |
5004 |
Warning |
Too many selections |
Limit to 10 locations when using drive time in Information. |
You have selected more than the allowed number of features when using selections and drive time in the Information tool. |
5005 |
Information |
Recenter the map to enable information data. |
The area that your infographic card represents is not currently shown on the map. Recenter the map. |
5999 |
Warning |
Unexpected error |
Work with layers
The following messages may occur when working with layers.
Code |
Category |
Title |
Message |
Description |
6001 |
Error |
The following invalid characters will be removed from the layer name list ( $, <, >). |
An attempt was made to use invalid characters when naming your layer. |
6002 |
Information |
More than 200+ values |
Values not listed here will still display on the map in this category. |
No more than 200 unique values can be displayed. |
Select features
The following messages may occur when selecting features.
Learn more about Selection tools
Code |
Category |
Title |
Message |
Description |
7001 |
Warning |
Select up to |
Selection has a maximum limit. |
Sign in
The following messages may occur when signing in.
Learn more about signing in to ArcGIS
Code |
Category |
Title |
Message |
Description |
8001 |
Error |
The specified ArcGIS Online or ArcGIS Enterprise URL is not valid. |
8002 |
Information |
You don't have access to this resource. |
Add permissions for this resource to your account or switch accounts. |
8003 |
Information |
Public ArcGIS Online account not supported |
Sign in with ArcGIS Online organizational account. |
ArcGIS public accounts are not supported. Sign in to ArcGIS with an organizational account. |
8004 |
Error |
Subscription has expired since |
Subscription expired. Contact your administrator or Esri Support. |
8005 |
Error |
Subscription has been cancelled. |
An ArcGIS subscription may be canceled if it expires or if all credits are used. Contact your administrator or Esri Support to get a new license. |
8006 |
Error |
Subscription has been disabled |
Your subscription has been disabled because you consumed all your credits. |
Your subscription has been suspended. Possible reasons for suspension include: the subscription has expired, the credit balance is zero or negative, and the organization's subscription has reached its capacity. Contact your administrator or Esri Support. |
8007 |
Error |
Subscription in a restricted state |
Subscription restricted. An organization is moved to a restricted state when it uses all of its credits. With an organization that is in a restricted state, access to some capabilities and workflows is blocked. Contact your administrator or Esri Support. |
8008 |
Error |
Your organization has used all available credits and could enter restricted status. |
You are attempting to sign in to an organization that has used all available credits. An organization is moved to a restricted state when it uses all of its credits. With an organization that is in a restricted state, access to some capabilities and workflows is blocked. Contact your administrator or Esri Support. |
8009 |
Error |
Invalid URL |
Check the URL and reenter the proper address to sign in. |
8999 |
Warning |
Unexpected error |
Share
The following messages may occur when working with the Share | Export pane.
Learn more about content sharing
Code |
Category |
Title |
Message |
Description |
10001 |
Information |
Unable to find shared information |
A new layer would be published upon sharing. |
A previously shared layer may have been deleted. |
10002 |
Information |
A new map would be created upon sharing. |
10003 |
Error |
The size of the summary text cannot be more than 2,048 characters. |
Your summary is too long. Keep summary text under the character limit. |
10004 |
Error |
The size of the title cannot be more than 256 characters. |
Your title is too long. Keep title text under the character limit. |
10005 |
Error |
The size of the tag text cannot be more than 256 characters. |
Your layer tags have exceeded the limit. Keep tag text within the character limit. |
10006 |
Error |
Enter a title for the map. |
A map title is required. Add a title before sharing. |
10007 |
Error |
Enter a title for the layer. |
A layer title is required. Add a title before sharing. |
10008 |
Warning |
Unable to connect to the server |
Connection to server lost. Check your internet connection. |
10999 |
Warning |
Unexpected error |
The following messages may occur when exporting a printer-friendly page of a map in various formats.
Code |
Category |
Title |
Message |
Description |
11001 |
Error |
The size of the copyright text cannot be more than 250 characters. |
Copyright text has exceeded the limit. Keep text within the character limit. |
11002 |
Error |
The map has a large number of client-side features |
Zoom in and retry printing, or click the Screenshot option. |
The printing service has a limit for client-side features. Zoom in and retry printing, or click the Screenshot option. |
11003 |
Error |
The title has exceeded the limit. Keep text within the character limit. |
Navigation tools
The following messages may occur when working with navigation tools, home extent, or bookmarks.
Learn more about navigation tools
Code |
Category |
Title |
Message |
Description |
12001 |
Information |
Home extent unavailable |
Your home extent is outside the boundaries of |
When trying to navigate to the home extent, the home extent is located out of bounds when compared to the basemap's full extent. Clear the home extent and reset within the basemap bounds. |
12002 |
Information |
Map extent is locked |
Zoom to |
The map must be unlocked to zoom to this layer. |
12003 |
Information |
Unlock map extent to use bookmarks. |
The map is locked, preventing panning. Unlock the map to navigate to other locations to bookmark. |
12004 |
Error |
Link must start with https://. |
Thumbnail link must start with the proper address format. |
12005 |
Error |
Link may not contain file:. |
Image link must be in correct format. |
12006 |
Error |
Invalid URL |
The image URL is not valid. Check and try again. |
12007 |
Information |
Your location services or permissions must be enabled to navigate to your current location. |
Layer styling
The following messages may occur when configuring layer styling, such as renderer, labeling, and so on.
Learn more about styling map layers
Code |
Category |
Title |
Message |
Description |
14001 |
Warning |
Arcade expression is not supported for changing its configuration when used in layer renderers. |
Layers with Arcade expressions are not supported. Choose a different layer. |
Application
The following messages may occur when downloading or updating an application.
Code |
Category |
Title |
Message |
Description |
15001 |
Information |
Update available |
Ask your administrator to update to the latest version. |
Upgrade to the latest version. |
Spatial aggregation
The following messages may occur when using the Spatial aggregation tool.
Learn more about aggregating features
Code |
Category |
Title |
Message |
Description |
18001 |
Error |
Spatial aggregation failed. |
18002 |
Error |
Your result layer name must be within the character limit. |
18003 |
Error |
A result layer already exists with this name. Use a different name. |
You cannot use an existing result layer name. Choose a unique layer name. |
18004 |
Error |
The result layer name contains one or more invalid characters. |
The result layer name must contain valid characters only. Check your input and adjust. |
18005 |
Error |
Credits are required to perform this analysis. Contact your administrator or Esri Support. |
18006 |
Error |
Spatial aggregation failed |
The feature service couldn't be created. |
18007 |
Error |
18008 |
Error |
Result layer cannot be found in |
Try again or contact your administrator or Esri Support. |
Uncategorized
The following message occurs unexpectedly.
Code |
Category |
Title |
Message |
9999 |
Warning |
Unexpected error |
