Use pop-ups
In ArcGIS for SharePoint, a pop-up contains descriptive information about the features in each layer in a map. It displays attribute information based on the field values that you added to a map. A pop-up displays when you hover over or click a feature on a data layer, a reference layer, or a buffer/drive time layer.
You can change the way information is presented in a pop-up by changing the data and specifying the fields to display.
Tip:
To anchor a pop-up on your screen while you pan and zoom the map, click the Dock button
on the pop-up.
You can enable pop-ups in the Layer options pane. Some ArcGIS layers do not support pop-up configuration; in this case, the pop-ups option is not available in that pane.
Enable and configure pop-ups
To enable and configure pop-ups, complete the following steps:
In the Layers pane, click the Layer Properties tab
.Choose a layer to modify from the Active layer drop-down menu.
Expand the Pop-ups section.
Turn on the Enable pop-ups toggle button to view the available options.
Optionally, do any of the following to change how the listed fields appear in the pop-up:
Select a Title field option to display in a feature's pop up.
From the Layer fields to include drop-down menu, select the fields that will appear in the pop-up. Reorder the fields by dragging a field to a new location in the list.
If available, reorder any listed fields to appear above or below the Layer fields to include menu.
Click the Layers tab
to return to the Layers list.
