Extract EXIF data from images
Exchangeable image file format (Exif or EXIF) is a format used for images shot on digital cameras and drones that include metadata for the image including coordinates and other GPS information. The Extract EXIF data tool in ArcGIS for SharePoint is a client-side tool that allows you to extract selected metadata from EXIF images, store the information in the SharePoint document library, and use the location information to add the data as points on a map. When using the tool, you can also turn on the Power Automate flow toggle button for all newly added images, which allows you to set up a flow that automatically extracts the data from new images added to your SharePoint library.
Caution:
Setting up the Power Automate flow requires a premium Power Automate license and your Microsoft administrator must approve the PowerApps API Service. See System requirements in the Install and manage ArcGIS for SharePoint topic for information about API access.
Tags allowed by ArcGIS for SharePoint
You can extract the following tags using the Extract EXIF data tool; however, extracting Exif.GPSInfo.GPSDestLatitude (GPSLatitude) and Exif.GPSInfo.GPSDestLongitude (GPSLongitude) ensures you have the coordinates for mapping.
For more information about EXIF tags and the data that can be extracted, see the Standard Exif Tags article on the Exiv2 website.
GPSInfo |
Image |
GPSLongitudeRep |
DateTime |
GPSLongitude |
DateTimeOriginal |
GPSAltitudeRep |
Imagewidth |
GPSAltitude |
Imagelength |
GPSTimeStamp |
BitsPerSample |
GPSSatellites |
Compression |
GPSStatus |
PhotometricInterpretation |
GPSMeasureMode |
DocumentName |
GPSDOP |
ImageDescription |
GPSSpeedRef |
Make |
GPSSpeed |
Model |
GPSTrackRef |
StripOffsets |
GPSTrack |
Orientation |
GPSImgDirectionRef |
SamplesPerPixel |
GPSImgDirection |
RowsPerStrip |
GPSMapDatum |
StripByteCounts |
GPSDestLatitudeRef |
XResolution |
GPSDestLatitude |
YResolution |
GPSLongitudeRef |
PlanarConfiguration |
GPSDestLongitude |
ResolutionUnit |
GPSDestBearingRef |
TransferFunction |
GPSDestBearing |
Software |
GPSDestDistanceRef |
Artist |
GPSDestDistance |
WhitePoint |
GPSProcessingMethod |
PrimaryChromaticities |
GPSAreaInformation |
JPEGInterchangeFormat |
GPSDateStamp |
JPEGInterchangeFormatLength |
GPSDifferential |
YCbCrCoefficients |
YCbCrSubSampling |
YCbCrPosition |
ReferenceBlackWhite |
Copyright |
Extract EXIF data
To extract EXIF data from images in your SharePoint document library, complete the following steps:
Open the SharePoint document library that contains your images.
Select the item or items from which you want to extract EXIF information.
To select the entire document library, continue without selecting any rows.
Click ArcGIS.
Click Extract EXIF data from the drop-down.
You may need to click the Options button.
The Extract EXIF data pane appears.
Under Images to extract from, select Entire document library or Selected items.
A count of the items is displayed.
Under Data to extract, search for and select the tags that you want to extract.
The extraction will create columns for each tag and populate the cell with the extracted information.
Click Run.
The extraction runs and a progress window appears. An error window appears if the image file has no EXIF data or if your ArcGIS connection token expires. Ensure the item has EXIF data or refresh the ArcGIS connection token in Power Automate to continue.
The SharePoint library is updated with each item's metadata.
The items are ready for mapping.
Set up a Power Automate flow for new images
You must have a Microsoft Power Automate premium license, and your Microsoft administrator must approve the PowerApps API Service. See System requirements in the Install and manage ArcGIS for SharePoint topic for information about API access.
To extract EXIF data from new images in your SharePoint document library using Microsoft Power Automate, complete the following steps:
Open the SharePoint document library that contains your images or a document library where you plan to upload images.
Click ArcGIS and Click Extract EXIF data from the drop-down.
The Extract EXIF data pane appears, and Entire document library is selected by default.
Under the Power Automate flow section, turn on the Automatically extract from new items toggle button.
Optionally, turn off the Automatically extract from new items toggle button to stop any new items from automatically having their data extracted.
Ensure your Power Automate environment, ArcGIS connection reference, and SharePoint connection reference are correct.
See Manage connections in Power Automate in the Microsoft documentation for more information about adding connections in Power Automate.
Click Run.
Clicking Cancel when running the tool will only stop the client-side tool that is extracting existing SharePoint document library items. The Power Automate flow will continue to run for newly added items.
Click Finish.
Delete the flow
Do the following steps to delete the flow from PowerAutomate:
Open the SharePoint document library.
Click ArcGIS, then click Extract EXIF data from the drop-down.
On the Extract EXIF data pane, under the Power Automate Flow section, click Delete flow. The flow will be deleted from PowerAutomate. This removes the PowerAutomate flow details from the SharePoint doc library's properties.
Click Cancel or continue with the deletion.
