Add and configure charts
Charts are visualization tools that allow you to display and compare data in a variety of layouts. When creating a chart, you choose a chart type, add data to a table, and configure the chart settings.
You can create the following types of charts:
  • Bar
  • Column
  • Line
  • Area
  • Donut
Add charts
You can add charts to stories, briefings, and frames.
  • In stories, you can add charts to the body of a story, sidecar narrative panels, and sidecar media panels. In the body of a story, you can add up to three charts side by side.
  • In briefings, you can add charts to briefing slide panels on all slide types except the cover.
  • In frames, you can add charts to frame slide panels on any slide except the cover.
To add a chart created in ArcGIS Map Viewer, see Linked charts.
Add chart data
Use the following tips when adding information to the chart data table:
  • Bar, column, line, and area charts can display up to three data series and 25 data values; donut charts display one data series and up to 12 data values.
  • Add category labels in the first column of the table. Add value labels in the first row of the table.
  • Category and value labels can be text or numeric. All other cells in the table must have numerical data.
  • Use the arrow keys to move keyboard focus around the data table. Press Enter to turn on or off cell editing.
  • You can paste tabular data copied from other sources into the data table.
  • Click Clear data to remove all information from the table. For example, you can remove placeholder data or when you want to start over while keeping the same chart settings.
Bar and column chart settings
The following settings are available for bar and column charts:
  • Chart type—Optionally, change the chart type after creating a chart.
  • Series color—Choose a color for each data series using the color picker.
  • Display multiple series—Choose how to display multiple data series: side-by-side, stacked, or 100% stacked. This option is only available if multiple data series have been entered in the data table.
  • Chart title—Optionally, type a title for the chart. The title appears above the chart.
  • Category axis title—Optionally, type a title for the category axis.
  • Value axis title—Optionally, type a title for the value axis.
  • Customize axis—Optionally, enable this to set a maximum for the value axis.
  • Show legend—Show or hide the legend. This setting is disabled when there is only one data series.
  • Show gridlines—Show or hide the value axis gridlines.
  • Show data labels—Show or hide labels for each data value.
For bar and column charts, corner styling follows the active theme; it isn't a chart setting.
Line and area chart settings
The following settings are available for line and area charts:
  • Display multiple series—Choose how to represent multiple series for an area chart: overlapping, stacked, or 100% stacked. This option is only available if multiple data series have been entered in the data table.
  • X-axis title—Optionally, type a title for the x-axis.
  • Value axis title—Optionally, type a title for the y-axis.
  • Customize axis—Optionally, enable this to set a maximum or minimum for the value axis for a line chart or a maximum for the value axis for an area chart.
  • Show gridlines—Show or hide the x- and y-axis gridlines.
  • Smoothed lines—Use straight or smoothed lines to connect data values.
Donut chart settings
The following settings are available for donut charts:
  • Color palette—Choose an accessible color palette for the donut chart segments.
  • Use custom colors—Enable this to select your own colors for each donut chart segment.
  • Show data labels—Show or hide labels for each donut segment.
  • Show values—Show or hide values for each donut segment. This option is only available when Show data labels is enabled.
Chart options
The Data source option allows you to cite the data source for the chart. The data source is available to readers by hovering over the information icon shown in the upper corner of the chart.
Best practices
Consider the following best practices when creating charts:
  • For donut charts, include a small number of categories.
  • Use bar, column, or donut charts for categorical data.
  • Use a line chart for time-series data.
  • Include a data source in Chart options or in the chart caption.
  • Configure consistent value axis bounds for each chart when using side-by-side charts for direct comparison.
Additional resources
