Add and configure infographics
Infographics are visualization tools that present simple data in an engaging layout. You can create the follow types of infographics:
  • Large number
  • Word cloud (beta)
  • Pictograph (beta)
Add infographics
You can add infographics to stories, briefings, and frames:
  • In stories, you can add infographics to the body of a story, sidecar narrative panels, and sidecar media panels. In the body of a story, you can add up to three infographics of the same type side by side. Infographics placed in a row must use the same layout.
  • In briefings, you can add infographics to briefing slide panels on all slide types except the cover.
  • In frames, you can add infographics to frame slide panels on any slide except the cover. Only the stacked and basic layouts are available for large number infographics.
Create a large number infographic
To create a large number infographic, provide a number, short description, and icon; choose an infographic layout; and configure display settings.
There are four layouts:
  • Basic—Center-aligned number and description
  • Stacked—Center-aligned icon, number, and description
  • Compact—Side-by-side icon and number above a center-aligned description
  • Titled—Center-aligned description above an icon and number
Tip:
Use the following tips to create effective large number infographics:
  • Use an abbreviation for long numbers; for example, type 27M instead of 27,000,000.
  • A description should be concise, ideally no longer than two lines.
  • You can use a short word instead of a number.
  • Use the basic layout when an icon isn't needed.
Large number settings
The following settings are available for large number infographics:
  • Layout—You can change the layout after creating an infographic.
  • Colors—Choose colors for the text, icon, and background using the color picker.
Tip:
Choose a background color that provides sufficient contrast with other infographic elements. See Color choices.
Create a word cloud
A word cloud is a representation of a long selection of text that displays words in different font sizes by their relative frequency. You type or paste a selection of source text for the word cloud.
Word cloud settings
The following settings are available for word cloud infographics:
  • Colors—Choose colors for the text and background using the color picker.
  • Direction—Choose from Horizontal, Orthogonal, or Multidirectional.
Create a pictograph
A pictograph uses repeated icons to represent quantities, categories, or a proportion.
There are two types of pictographs:
  • Single value—A value is represented by a number of icons.
  • Part to whole—A proportion is represented by the number of colored icons compared to the number of uncolored icons.
You specify the number and arrangement of icons and can add a title and legend label text to describe the pictograph data.
Pictograph settings
The following settings are available for pictograph infographics:
  • Layout—Change the pictograph representation between single-value and part-to-whole.
  • Colors—Choose colors for the text, icons, and background using the color picker.
Infographic options
The Alternative text field can be used to enter descriptive text for the infographic that will be announced by screen readers.
You can use the Data source field to enter text to credit the data source for the infographic. Readers can see the data source by hovering over the information icon shown in the upper corner of the infographic.
Resize infographics
In a story, to change the size of a block, hover over the block and click Small, Medium, or Large. Alternatively, you can choose Float left or Float right to position the block on one side of the page and have text flow around it.
Best practices
Keep the following in mind when making infographics:
  • Choose an icon that relates to the theme of the data value represented.
  • Consider including a data source in Infographic options.
Additional resources
