Create quizzes
Create a quiz to engage readers with questions about your content.
Add quizzes
You can add quizzes to stories and frames:
  • In stories, you can add a quiz to the body of a story.
  • In frames, you can add a quiz to a single-panel slide.
Use the following steps to add a quiz:
  1. Click the Add content block button to open the block palette.
  2. Select Quiz.
A new quiz is added. Next, add questions to the quiz, as described below.
Add questions
Use the following steps to add questions to a quiz:
  1. Configure the first question.
    1. Select the question type:
      • Single Selection—Readers can choose one answer.
      • Multiple Selection—Readers can choose more than one answer. Mark each answer that must be selected for the response to be correct.
    2. Replace the placeholder text with the question and answer choices for the first quiz question.
    3. To add media to the question, click Show media in the question toolbar and add an image or map.
    4. After entering the answer choices, mark the correct answer or answers.
    5. To add explanations for answer choices, including incorrect answers, or a hint, click Edit quiz and Question options.
  2. To add more questions, click Edit quiz and Add question.
Configure the result screen
Readers see a result screen, which you can customize, after they complete a quiz.
Use the following steps to customize the result screen:
  1. Hover over the quiz, click Edit quiz, and click Result screen options.
  2. Optionally, edit the completion message.
  3. Optionally, enter additional information.
  4. To remove the Restart button from the result screen, uncheck Allow readers to retake this quiz.
  5. Click Save.
The result screen options are saved.
Delete a quiz
To delete a quiz block, hover over it, click Edit quiz, and click Delete quiz.
