Add and configure tables
Tables are visualization tools that display data in a tabular layout. You can use a table to structure and organize information and understand patterns.
Add tables
You can add tables to stories and briefings:
  • In stories, you can add tables to the body of a story and sidecar narrative panels. A table can have up to 8 columns and 13 rows.
  • In briefings, you can add tables to briefing slide panels on flexible layout slides. A table can have up to 6 columns and 6 rows. The size of the briefing panel will affect how much of a table is visible without scrolling.
Enter table data
Use the following tips when entering data into a table:
  • Hover over the table and click the Row options button or Column options button to show controls for adding and deleting table elements.
  • Table rows and columns will automatically resize based on the length of information in each cell.
  • You can format, add links to, and align text in table cells by highlighting the text and selecting options from the toolbar.
Table options
Hover over a table and click Options on the toolbar to configure the following options:
  • Show header row—Show or hide a shaded header row at the top of the table. The header row is enabled by default.
  • Show header column—Show or hide a shaded header column at the start of the table. The header column is disabled by default.
Best practices
Consider the following tips when making tables:
  • In Table options, use a header row or header column to label or categorize data.
  • Maintain consistent text alignment across a table, or at minimum within each column.
  • Consider including a data source in the table caption.
Additional resources
