Report expressions
The response to a question can be displayed in a report template by providing its name enclosed in curly brackets {}, and preceded by a dollar sign. Any string value included in an expression must be enclosed in double quotes.
The following example displays the response from a text question called firstname:
${firstname}
In addition to displaying the response to a question in a report, keywords can be used to display other useful information. The following displays the current date and time when printing a report:
${$date}
If the result is an array, the array can be iterated using # as a start tag and / as an end tag within the curly brackets. The following prints all image files on separate lines:
${#image1}
${$file}
You can also use expressions to refine how responses are displayed. An expression can be a single question name or keyword (as above), a calculation involving one or more questions or keywords, or a question name or keyword with methods and parameters to constrain or apply style to the response. An expression uses the following notation:
${questionname or keyword | method:parameter}
An expression can include multiple methods and parameters or none at all. Parameters can be either values from other questions or a fixed value.
The following expression displays the calculation of a number question named floweringtrees divided by a number question named totaltrees. When referring to multiple questions in the same expression, the individual question names only need to be directly named and do not need additional curly brackets:
${floweringtrees / totaltrees}
The following expression displays the x-coordinate value from the location question in which getValue is the method and x is the parameter:
${location | getValue:"x"}
The following expression evaluates as true if the response to a question named fruitcolor is not equal to red:
${if fruitcolor!="red"}The fruit is not red.${/}
Strings can be concatenated in an expression by joining them with a plus sign. The following expression uses this concatenation to pass the contents of a question named field_0 to a QR code-generating service, creating a QR code for the question's response:
${$image | src:"https://barcode.tec-it.com/barcode.ashx?code=QRCode&data="+field_0}
Example expressions for each type of question, are available in the following topics:
Map expressions (includes geopoint, geotrace and geoshape)
Expression methods
Not all question types support expressions and methods. The following table lists the methods and parameters you can use with various question types:
Method |
Parameter |
Connect question type |
Web designer question type |
Description |
getValue |
All question types |
Retrieves the raw data value from the feature layer or raw image from an attachment. |
getValue |
x, y, z, wkid |
geopoint |
Map |
Retrieves the x-, y-, z-coordinates individually in a specified spatial reference. The |
getValue |
length, area, unit, measurement type |
geotrace, geoshape |
Map |
Returns the length of a polyline or the perimeter or area of a polygon, in given units and specifies whether the measurements are planar or geodesic. The default measurement type is geodesic. |
getValue |
name, size |
image, audio, file |
Image, Signature, Audio, File |
Returns the file name or size of an attachment. |
getValue |
width, height, x, y, date, time, direction |
image |
Image, Signature |
the width and height return the integer value of the image width and height in pixels, and x, y, date, time, and direction return values read from the image EXIF if present. |
getValue |
count |
begin repeat, image, audio, file |
Repeat, Image, Signature, Audio, File |
Returns the total count of repeats or attachments. |
getValue |
position |
Returns an integer equal to the 1-indexed position in the array. |
getValue |
duration |
audio, file |
Audio, File |
Returns the length of audio recordings in seconds. Caution:Duration is not returned in responses collected in the web app when using Safari. |
appearance |
multiline |
text |
Multiline text |
Retains the line breaks in the string. If no appearance value is specified, a single line string is returned. |
appearance |
bullets |
select_multiple |
Multiple select |
Returns answer in bullet format. |
checked |
choice name |
select_one, select_multiple |
Multiple select, Single select, Single select grid, Dropdown, Likert scale, Rating |
Returns a checked check box if the field value equals the choice name; otherwise, returns an unchecked check box. |
selected |
choice name |
If a coded value domain exists, returns true if the field value equals the choice name; otherwise, returns false. |
countSelected |
Returns the number of selected choices. |
selectedAt |
index |
Returns the string at the index position in the choice list. The index starts at zero. |
locale |
language code |
date, dateTime, start, end, decimal |
Date, Date and time, Number |
Returns the localized date, time, and number. |
format |
format string |
date, dateTime, integer, decimal, start, end |
Date, Date and time |
Returns a formatted date string. |
utcOffset |
offset value |
date, dateTime, start, end |
Returns a date or date-time value that is shifted by the UTC offset value. |
mapSettings |
web map item ID, map scale |
geopoint, geotrace, geoshape |
Map |
Specifies the basemap and scale when printing the map image. Legacy:This method has been replaced by |
mapExtent |
xmin, ymin, xmax, ymax, wkid |
Map |
Specifies the fixed map extent when printing the map image. The |
map |
web map item ID |
Map |
Specifies the basemap when printing the map image. |
mapScale |
map scale |
Map |
Specifies the map scale when printing the map image. |
mapFilters |
layer ID in web map JSON, query parameters |
Map |
Specifies one or more filters of feature layers in a web map when printing the map image. |
rotate |
degrees |
geopoint, geotrace, geoshape, image |
Map, Image |
Specifies the rotation angle of the map or image. |
drawingInfo |
currentLayer, feature layer URL |
Map |
Specifies the drawing information when printing the map image, including symbol, label, and transparency. |
src |
image URL |
Specifies the source URL of a dynamic image element. |
size |
width, height, max width, max height |
image |
Image |
Specifies the size of the printed image. |
round |
places |
decimal, geopoint, geoshape, geotrace |
Number |
Rounds a decimal number to specified decimal places. |
useGrouping |
boolean |
decimal |
Number |
If true, returns a number with grouping separators determined by the locale; if false, no separators are used. |
toFixed |
places |
Number |
Specifies a fixed number of digits after the decimal separator. It will pad zero if required to meet a fixed number of digits. |
attachmentsDefExp |
SQL expressions |
Identifies attachments for a question or the current feature using the |
Expression keywords
The following table lists all keywords that can be used in an expression:
Keyword |
Description |
$date |
Inserts the current date and time when printing the report. By default, it outputs the current date using the current locale format. Examples:
$image |
Inserts an image element in the report. Use the Example:
$map |
Inserts a map element in the report without referencing a survey question. Example:
$shape |
Prints the geometry (point, polyline, or polygon) of the current feature on a map. Examples:
$attachment |
Represents the first attachment, or all attachments, of the current feature. Examples:
To iterate all attachments, include start and end tags.
$file |
Represents the current file when iterating multiple files of an attachment survey question or attachments of a feature. Examples:
$feature |
Represents the current feature in an array of features. Example:
$layers["<layername>"] or $layers[<layerId>] |
References any layer by name or ID in the same feature service as the survey layer. Examples:
