Functionality matrix
Survey123 Studio and Survey123 Mobile are successor apps to Survey123 Connect and the Survey123 field app.
The next generation apps do not have all the functionality of Survey123 Connect and the Survey123 field app. Functionality has been prioritized in order of the most important elements of the apps, but there will inevitably be some features that you use that are not there.
The tables below list the status of functionality of Survey123 Studio and Survey123 Mobile with respect to features available in Survey123 Connect and the Survey123 field app.
Survey123 Studio and Survey123 Mobile do have new features (for example, tabular repeats and a big-button data capture experience with the support of ArcGIS QuickCapture projects) that are documented throughout the website. For the latest additions, see What's new in Survey123.
The information in this topic is grouped by app features so you can quickly scan what's available, what's in development, and what's planned or not planned.
The following statuses are used in the tables below:
  • Available—Functionality is available for use now. Some limitations may apply, but they are described in the specific documentation
  • In development—Work is in progress on the functionality, and it will be available in the next release or two.
  • Planned—Work on the functionality is not in progress, but it is planned for a future release.
  • Not planned—The functionality is not planned for inclusion in Survey123 Studio or Survey123 Mobile. It may be superseded by newer behavior or technology, or is no longer applicable.
The Survey123 field app beta features (for example, add-ins and compass) are not supported and are not planned for future releases of Survey123 Mobile.
XLSForm
If your surveys rely on any of the questions or behaviors listed below as Planned, continuing to use the Survey123 field app may be the best solution to address your needs at this time.
However, you are encouraged to make a copy of your survey in Survey123 Studio to test it. If it works as you expect, you can publish it and use it in Survey123 Mobile. Before publishing, you can also modify the survey.
Common to all question types, the following columns are available for use in Survey123 Mobile and Survey123 Studio:
  • required
  • required_message
  • readonly
  • default
  • calculation
  • constraint
  • constraint_message
  • hidden
The following tables are grouped by question so you can quickly see what is available, in development, and planned:
Text questions
Functionality
Status
Notes
appearance - none
Available
appearance - multiline
Available
Includes the defaultHeight parameter
appearance – hidden
Available
body::esri:style - placeholderText
Available
bind::esri:fieldLength
Available
appearance - geocode
Available
appearance - inframarker
Planned
appearance – getinframarkerid
Planned
body::esri:inputMask
Planned
appearance - Nopredictivetext
Planned
appearance - Predictivetext
Not planned
appearance – rangefinder
Not planned
bind::esri:workflow
Not planned
bind::saveIncomplete
Not planned
Integer and decimal questions
Functionality
Status
Notes
appearance - none
Available
appearance - hidden
Available
appearance - spinner
Available
Available
bind::esri:parameters - calculationMode parameter
Available
appearance - numbers
Planned
appearance - calculator
Planned
appearance - thousands-sep
Planned
rangefinder
Not planned
distress
Not planned
Applies to integer only. The alternative is to use range.
Multiple choice questions
Functionality
Status
Notes
appearance - none
Available
appearance - hidden
Available
appearance - autocomplete
Available
Autocomplete is now available for select multiple as well as select one questions.
appearance - minimal
Available
appearance - compact
Available
appearance - horizontal
Available
appearance - horizontal-compact
Available
appearance – likert
Available
Available
choice_filter
Available
or_other
Available
external_choices
Available
choice audio
Available
choice image
Available
randomize
Available
media::audio
Available
media::image
Available
appearance - search()
Available
Available
appearance - compact-n
Planned
appearance - image-map
Planned
In the current release, these questions display as a select question with no appearance.
Not planned
Date and time questions
Functionality
Status
Notes
appearance - none
Available
appearance - hidden
Available
appearance - year (date only)
Available
appearance - month-year (date only)
Available
appearance - week-number (date only)
Available
date formats
Available
Available
Not planned
Range questions
Functionality
Status
Notes
appearance - none
Available
appearance - hidden
Available
appearance - no-ticks
Available
body::esri:style - startColor, endColor, color parameters
Available
Start, stop, step parameters
Available
Note questions
Functionality
Status
Notes
appearance - none
Available
appearance - hidden
Available
media::audio
Available
media::image
Available
generated note - generated_note_form_title
Available
Available
Other forms of the generated note
Planned
Geopoint questions
Functionality
Status
Notes
appearance - none
Available
appearance - hidden
Available
appearance - press-to-locate
Available
body::accuracyThreshold
Available
bind::esri:warning
Available
coordinate format, esriFieldTypeZ
Available
Offline basemaps
In development
bind::esri:parameters - calculationMode and geocode parameters
Available
Geosearch
Available
body::esri:style - height, map, map tools, minCaptureZoomLevel, overlay, precision, snapMode, symbol parameters
Planned
hide-input
Not planned
Supported in the web app only.
Geotrace and geoshape questions
Functionality
Status
Notes
appearance - none
Available
appearance - hidden
Available
Available
Planned
bind::esri:warning
Available
Available
Available
Offline basemaps
In development
Geosearch
Available
body::esri:style - lineColor, lineWidth, fillColor, method=vertex,streaming,noedit,distanceThreshold
Available
body::esri:style - height, map, map tools, minCaptureZoomLevel, overlay, precision, snapMode, symbol parameters, method=vertex,beep,haptic
Planned
Repeats
Functionality
Status
Notes
appearance - none
Available
appearance - hidden
Available
Available
appearance - minimal compact
Available
Available
Fixed grid style
Available
body::esri:style - backgroundColor, borderColor parameters
Available
nested repeats
Available
body::esri:style - layout parameter (grid styles)
Available
Fixed grid style is available, dynamic grid style is planned.
appearance - field-list (pages)
Planned
bind::esri:parameters - allowAdds, allowUpdates, query parameters
Planned
repeat_count
Planned
Groups
Functionality
Status
Notes
appearance - none
Available
appearance - hidden
Available
Available
Fixed grid style
Available
Available
nested groups
Available
Available
Available
appearance - table-list
Planned
Media questions
Functionality
Status
Notes
appearance - none
Available
appearance - hidden
Available
Available
appearance – signature
Available
resize (Survey123 Studio setting)
Available
appearance - draw
Planned
appearance - annotate
Planned
appearance - new-rear
Planned
appearance - new-front
Planned
appearance - signature multiline
Planned
body::esri:style - allowRename, fileNameVisible, method, previewHeight
Planned
body::esri:style - max-pixels parameters
Planned
bind::esri:parameters - allowAdds, fileName, max-size, watermark, topLeftWatermark, topCenterWatermark, topRightWatermark, leftCenterWatermark, centerWatermark, rightCenterWatermark, bottomLeftWatermark, bottomCenterWatermark, bottomRightWatermark parameters
Planned
default image (for signature, draw, and annotate appearances)
Planned
appearance - spike
Not planned
appearance - spike-full-measure
Not planned
appearance - spike-point-to-point
Not planned
bind::esri:parameters - smartAnnotation, smartAttributes, redaction
Not planned
AI image and text analysis tools are available.
Audio
appearance - none
Available
appearance - hidden
Available
bind::esri:parameters - codec, fileName, max-duration, max-size parameters
Available
File
File questions
Planned
In the current release, a message appears in place of the file selector.
Barcode questions
Functionality
Status
Notes
appearance - none
Available
appearance - hidden
Available
Available
body::esri:style - placeholderText parameter
Available
body::esri:style - barcodeType parameters
Not planned
Calculate questions
Functionality
Status
Notes
appearance - none
Available
Available
Hidden questions
Functionality
Status
Notes
appearance - none
Available
Available
Rank questions
Functionality
Status
Notes
Rank questions
Planned
Form expressions
Functionality
Status
Notes
boolean, comparison, conditional, numeric, string functions
Available
date(), date-time(), decimal-date-time(), decimal-time(), format-date(), int(), number(), string()
Available
today(), now()
Available
mathematical and preload functions
Available
regex
Available
calculationMode
Available
once()
In development
pulldata() Retrieve a value from a .csv file
Planned
pulldata("@exif")
Available
pulldata("@geopoint")
Available
Altitude, speed, and direction are unexpectedly shown as 0 instead of blank when no data is available using pulldata("@geopoint").
Reverse geocoding in pulldata("@geopoint") is available.
pulldata("@javascript")
Available
Repeats as an input to pulldata("@javascript") is planned.
pulldata("@json")
Available
pulldata("@layer")
Available
pulldata("@property")
Available
The submissionUrl, locale, and localeInfo properties are planned.
choice functions
Available
geometric attributes (distance, area)
Planned
repeat value aggregation (min, max, sum, count)
Available
repeat value aggregation (join)
Planned
repeat functions (indexed-repeat)
Available
repeat functions (position)
Available
Survey123 Studio
The following table lists functionality of Survey123 Connect, and the current status in Survey123 Studio:
Functionality
Status
Notes
Sign in to ArcGIS Online and ArcGIS Enterprise
Available
PKI is planned.
Create surveys
Available
It is recommended that you create new surveys from your existing organization surveys to use in Survey123 Mobile.
Creating surveys from existing feature services is planned.
Support for organization settings set on the Survey123 website is planned.
Publish surveys
Available
Internationalization and translation
Available
Accessibility
Available
Focus has been on adaptable text size, colors , names information and roles (for screen readers), and keyboard navigation, all within constraints of each platform's capabilities.
Form gallery
Available
Form tabs (Form, Details)
Available
Form tabs (Options, Map, Media, Linked Content, Scripts)
Planned
Options are available for image size and editing sent records. Linked content is available for CSV files to use as external choice lists.
Survey tools
Planned
Download surveys
Available
Delete surveys
Available
In this release, deleting a survey from Survey123 Studio only deletes the files from your PC. The item in your organization is not deleted. Deleting the item in your organization is planned.
Organization settings (General, Map, Surveys, Location sharing, Extensions)
Planned
More actions (Show QR code, Open in the web app, Manage in the Survey123 website, view item in your ArcGIS organization)
Planned
Survey123 Mobile
The following table lists functionality of the Survey123 field app, and the current status in Survey123 Mobile:
Functionality
Status
Notes
Sign in to ArcGIS Online or ArcGIS Enterprise
Available
PKI is planned.
Use public surveys
Available
Download surveys
Available
Send surveys
Available
Delete surveys
Available
Available
Accessibility
Available
Focus has been on adaptable text size, colors, names information and roles (for screen readers), and keyboard navigation, all within constraints of each platform's capabilities.
Sent, Outbox, Drafts
Available
Sent surveys open in view and edit modes only. The copy option is planned.
Sort is planned.
Map view: Only displays symbols for records; labels and selection are planned.
Inbox
Planned
App linking
Available
The action, folder, filter, center, field:fieldname, portalUrl, itemID, download, callback, and callback:status parameters are supported.
Support for the update and q:queryparameter parameters is planned.
Planned
Enterprise deployments
Planned
Location sharing
Planned
Location provider
Available
Integrated location provider and Bluetooth GNSS receivers only.
Location alerts are planned.
Themes
Available
Light and dark mode of system is honored. Personalization setting is available in the app.
Settings
Available
Measurement units, diagnostic logging, personalization, and data management (autosend interval) are supported.
Location providers are supported.
Webhooks
Available
Must use ArcGIS feature service webhooks (not Survey123 webhooks).
