ArcGIS for Teams errors, messages, and warnings
The following sections and tables are a log that provides a list of errors, warnings, information, and validation messages you may encounter when using ArcGIS for Teams.
Message codes are defined as integers and organized into groups based on categories of service.
Add an ArcGIS layer
The following messages may occur when adding a layer from ArcGIS:
Code
Category
Title
Message
1001
Information
Web map cannot be added
There are no operational layers.
When adding a web map from ArcGIS Online, the source web map must contain operational layers such as a feature service, tile layer, or imagery layer.
1002
Information
Layer cannot be added
The coordinate system or tiling scheme must align with the basemap.
The layer coordinate system of the layer being added must match that of the basemap. Check the layer coordinate system and try again with an aligned layer.
1003
Warning
Layer cannot be added.
The layer cannot be added. Check the source item in your organization or contact your administrator.
1004
Error
Layer failed to fetch.
Your layer is unable to load on the map. Contact your administrator to troubleshoot.
1005
Information
Spatial reference incompatible.
This layer's spatial reference is incompatible with the spatial reference of the basemap. You can either use a different basemap and read the layer or you can open the item in ArcGIS Online and republish the item with a different coordinate system.
Learn more on the Incompatible with current basemap Technical Support page
1006
Error
The layer failed to copy.
Remove the layer you want to copy and add again or contact your administrator to check the layer properties in ArcGIS Online.
1007
Information
No access
You are currently signed in as Username. You do not have access to layer.
You do not have adequate permissions to add this content, for example, your user type, role, ArcGIS account, or organization settings do not allow this content, or the content is private or not shareable. Contact your organization administrator for more information.
1008
Information
The layer contains no data.
Your layer has no features to display on the map.
1009
Information
Unsupported Version
The version must be 2.0 or higher. The webmap can be resaved to a newer version.
This happens when adding a layer from ArcGIS Online that contains an incompatible web map version. Go to ArcGIS Online, open the web map, and resave to a current version.
1010
Error
The layer was deleted or has become inaccessible.
Your layer has been deleted or become inaccessible. Check the source layer or contact your organization administrator to troubleshoot.
1011
Warning
Query capability disabled
Check layer edit settings.
This appears when a layer does not have query capabilities and new geometries are recorded but hidden. To resolve, in the layer settings, change What features can editors see? from Editors can't see any features, even those they add to Editors can see all features.
Learn more on the Capability 'Query' is not set on the layer Technical Support page
1999
Warning
Unexpected error
Contact Esri Technical Support.
Add a data layer
The following messages may occur when adding a data layer from ArcGIS for Excel:
Code
Category
Title
Message
2001
Error
Adding data failed
Check your data source and try again.
Ensure your location data is correct and accessible.
2002
Error
The selected column doesn't contain any valid JSON geometry.
When adding Microsoft data as a JSON type, the geometry column must contain an attribute formatted in valid JSON format. Check your source data for import or formatting errors or choose a different attribute.
2003
Information
No ArcGIS World Geocoder or custom geocoders that support batching are configured
Contact your organization administrator.
Go to your portal and configure a geocoder that supports batching.
2004
Warning
Verify that your data has valid location information.
Your layer may not contain spatial data.
2005
Error
Layer failed to copy.
Remove the layer you want to copy, and add again.
2006
Error
The file contains invalid JSON.
JSON format not valid; check the source data for formatting or other errors and try again or select a different attribute.
2007
Error
Unknown spatial reference
Check the format of the CRS property in your GEOJson.
2008
Information
Large geometries were generalized to avoid memory issues.
Geometries were simplified to stay within memory limits.
2009
Error
File size limit of 500 MB exceeded.
Layer being added exceeds size limits.
2999
Warning
Unexpected error
Contact Esri Technical Support .
Work with basemaps
The following messages may occur while working with basemaps:
Code
Category
Title
Message
3001
Information
Basemap cannot be changed
The basemap and layer must have the same coordinate system.
Basemap and layer coordinate systems must be the same. Try again.
3002
Warning
Basemap cannot be loaded
Check the basemap service or select a different basemap.
Work with layers
The following messages may occur when working with layers:
Code
Category
Title
Message
6001
Error
The following invalid characters will be removed from the layer name list ( $, <, >).
An attempt was made to use invalid characters when naming your layer.
6002
Information
More than 200+ values
Values not listed here will still display on the map in this category.
No more than 200 unique values can be displayed.
Select features
The following messages may occur when selecting features:
Code
Category
Title
Message
7001
Warning
Too many selections
Select up to count locations or fewer.
Selection has a maximum limit.
Sign in
The following messages may occur when signing in:
Code
Category
Title
Message
8001
Error
The specified ArcGIS Online or ArcGIS Enterprise URL is not valid.
Contact your administrator or Esri Technical Support.
8002
Information
You don't have access to this resource.
Add permissions for this resource to your account or switch accounts.
8003
Information
Public ArcGIS Online account not supported
Sign in with ArcGIS Online organizational account.
ArcGIS public accounts are not supported. Sign in to ArcGIS with an organizational account.
8004
Error
Subscription has expired since MM/DD/YY
Subscription expired.
8005
Error
Subscription has been cancelled.
An ArcGIS subscription may be canceled if it expires or if all credits are used.
Contact your administrator or Esri Technical Support to get a new license.
8006
Error
Subscription has been disabled
Your subscription has been disabled because you consumed all your credits.
Your subscription has been suspended. Possible reasons for suspension include: the subscription has expired, the credit balance is zero or negative, and the organization's subscription has reached its capacity.
8007
Error
Subscription in a restricted state
Subscription restricted. An organization is moved to a restricted state when it uses all of its credits. With an organization that is in a restricted state, access to some capabilities and workflows is blocked.
8008
Error
Your organization has used all available credits and could enter restricted status.
You are attempting to sign in to an organization that has used all available credits. An organization is moved to a restricted state when it uses all of its credits. With an organization that is in a restricted state, access to some capabilities and workflows is blocked.
8009
Error
Invalid URL
Check the URL and reenter the proper address to sign in.
8999
Warning
Unexpected error
Share
The following messages may occur when working with the Share|Export pane:
Code
Category
Title
Message
10001
Information
Unable to find shared information
A new layer would be published upon sharing.
Previously shared layer may have been deleted.
10002
Information
A new map would be created upon sharing.
10003
Error
The size of the summary text cannot be more than 2,048 characters.
Your summary is too long. Keep summary text under the character limit.
10004
Error
The size of the title cannot be more than 256 characters.
Your title is too long. Keep title text under the character limit.
10005
Error
The size of the tag text cannot be more than 256 characters.
Your layer tags have exceeded the limit. Keep tag text within the character limit.
10006
Error
Enter a title for the map.
A map title is required. Add a title before sharing.
10007
Error
Enter a title for the layer.
A layer title is required. Add a title before sharing.
10008
Warning
Unable to connect to the server
Check your internet connection.
Connection to server lost. Check your internet connection.
10999
Warning
Unexpected error
Navigation tools
The following messages may occur when working with navigation tools, home extent, or bookmarks:
Code
Category
Title
Message
12001
Information
Home extent unavailable
Your home extent is outside the boundaries of basemap.
When trying to navigate to the home extent, the home extent is located out of bounds when compared to the basemap's full extent. Clear the home extent and reset within basemap bounds.
12002
Information
Map extent is locked
Zoom to layer is disabled.
Map must be unlocked to zoom to this layer.
12003
Information
Unlock map extent to use bookmarks.
The map is locked, preventing panning. Unlock the map to navigate to other locations to bookmark.
12004
Error
Link must start with https://.
Thumbnail link must start with the proper address format.
12005
Error
Link may not contain file:.
Image link must be in the correct format.
12006
Error
Invalid URL
The image URL is not valid. Check and try again.
12007
Information
Location access disabled
Location services or permissions must be enabled.
Your location services or permissions must be enabled to navigate to your current location.
Layer styling
The following messages may occur when configuring layer styling, such as renderer, labeling, and so on:
Code
Category
Title
Message
14001
Warning
Arcade expression is not supported for changing its configuration when used in layer renderers.
Layers with Arcade expressions are not supported. Choose a different layer.
Application
The following messages may occur when downloading or updating an application:
Code
Category
Title
Message
15001
Information
Update available
Ask your administrator to update to the latest version.
Upgrade to the latest version.
Uncategorized
The following message may occur unexpectedly:
Code
Category
Title
Message
9999
Warning
Unexpected error
