Install ArcGIS for Teams
You can install ArcGIS for Teams from the Microsoft AppSource to a personal (private) scope or to a selected team, chat, or meeting channel. You can also install a single content instance in an active channel, either as a content tab or a share tab.
It is recommended that you install ArcGIS for Teams in a channel from the Microsoft AppSource first.
Share, present, sketch and annotate tabs prompt
Before you can install ArcGIS for Teams, your IT administrator may need to manage apps in the Microsoft Teams admin center to make ArcGIS for Teams available to your organization.
Tip:
Confirm that you have permission from the channel owner to add ArcGIS for Teams to the selected location.
Install ArcGIS for Teams from the Microsoft AppSource
To install ArcGIS for Teams to a personal scope, team, chat, or meeting from the Microsoft AppSource, complete the following steps:
  1. In Microsoft Teams, click Apps from the options on the left to access the Microsoft AppSource.
    The Microsoft AppSource opens.
  2. In the Microsoft AppSource Search text box, type ArcGIS.
    ArcGIS (ArcGIS for Teams) appears in the search results.
  3. Click ArcGIS.
    The ArcGIS for Teams installation window appears containing information about this app, including an overview and permissions settings.
  4. To install the app, do one of the following:
    • To install to a personal scope, click Add. When ArcGIS for Teams is installed, a new private chat opens named ArcGIS for Teams. You can pin this to a private scope.
    • To install to a team, click the Add drop-down arrow and click Add to a team .
    • To install to a chat, click the Add drop-down arrow and click Add to a chat .
    • To install to a meeting, click the Add drop-down arrow and click Add to a meeting .
  5. For a team, chat, or meeting installation, at the browser prompt, browse to and select the channel, chat, or meeting to which you are adding ArcGIS for Teams and click Set up.
    ArcGIS for Teams is installed at the selected location.
  6. Click Save to save the installation.
Visit Search for ArcGIS content and ArcGIS for Teams Present and share in ArcGIS for Teams to learn more.
Install an ArcGIS for Teams content item in an active channel, call, chat, or meeting
A single ArcGIS for Teams content item can be added to a channel, call, chat, or meeting. Your team can engage with public ArcGIS content during a share session or, depending on your individual ArcGIS account sign-in status, with your organization's content or ArcGIS premium content on an ArcGIS for Teams content tab (not available for share).
To install an ArcGIS for Teams content item in an active channel, call, chat, or meeting, complete the following steps:
  1. In a Microsoft Teams channel, call, chat, or meeting, click the Add button in the top navigation.
    This button is named Add a tab in a chat or a team channel and Add an app in a call or a meeting.
    The Add a new app pane appears.
  2. In the Search for apps text box, type ArcGIS.
    ArcGIS appears in the search results.
  3. Click ArcGIS.
    The Sign in to ArcGIS pane appears.
    Sign in to ArcGIS pane for Teams
  4. Follow the prompts to sign in to your ArcGIS account or click Continue as guest. If you sign in, click Continue as <your username>.
    Options to confirm your user information for sign in
    Tip:
    If you leave Post to the channel about this tab checked (the default setting), a message that includes a search prompt is automatically posted to the channel's Posts tab.
    A prompt appears, asking which type of tab you want to install.
  5. Select Share content, Present a map, or Sketch and annotate.
    New tab or New Live Share tab prompt
    The ArcGIS for Teams Choose an item window appears.
  6. Follow the steps in either the Search for ArcGIS content or Start an ArcGIS for Teams share workflow to select an item to share.
  7. When you have selected an item to share, click Save.
    The item you select is added to the channel, call, chat, or meeting as a tab.
    • If you checked the Post to the channel about this tab check box, a notice about the item is shared in the channel's Posts tab.
    • If you chose Share content or Present a map, you can now share the item in a meeting.
Pin ArcGIS for Teams
To pin the ArcGIS for Teams private scope installation to the top of your chat list, right-click the More options button next to ArcGIS for Teams in the chat list and click Pin .
The pinned chat moves to the top of your chat list.
To unpin the installation, right-click More options and click Unpin .
Microsoft Graph permissions
Your app may need authorization from the Microsoft identity platform to access data in the Microsoft cloud, and granted the privileges that it needs. Similarly, your app may need authorization for Microsoft identity platform to access data through Microsoft Graph. See Overview of Microsoft Graph permissions to learn more about privileges.
In ArcGIS for Teams, permissions are only applicable for tasks, such as the following:
  • MeetingStage.Write.Chat—Show content on the meeting stage in meetings associated with a chat.
  • LiveShareSession.ReadWrite.Chat—Create and synchronize Live Share sessions for a chat.
  • LiveShareSession.ReadWrite.Group—Create and synchronize Live Share sessions for a team.
  • ChannelMeetingStage.Write.Group—Show content on the meeting stage of channel meetings associated with this team.
