Import shapefiles
You can add layers to ArcGIS for Teams by importing the shapefiles you have stored on your local machine.
In ArcGIS for Teams, use the Add layer pane to import a shapefile, and create a hosted feature layer.
Files exceeding the maximum supported size of 25 MB cannot be imported.
Open and import the file
  1. Open ArcGIS for Teams.
  2. Click Layers from the map tools.
  3. In the Layers pane, click +ArcGIS data if the layers are already added to your map.
  4. Click the File tab in the Add layer pane to begin uploading the shapefiles.
  5. Click Browse this device, or Browse OneDrive. These options allow you to either browse files stored on your local machine, or OneDrive. Optionally, you can also drag and drop a zipped shapefile from your local machine.
  6. Once you choose a shapefile from your local machine, or OneDrive the Create and add layer pane appears.
  7. The Source file is populated by default based on the shapefile you selected previously.
  8. The Title is populated by default based on the selected shapefile. Optionally, you can enter a new title.
  9. You can select how you would like to save the file from the Save as drop-down menu. For example, you can save as an ArcGIS feature layer.
    ArcGIS for Teams checks whether the specified ArcGIS feature layer name already exists. If a duplicate list name is found, an error message is displayed until a unique name is provided. Before importing, ArcGIS for Teams parses the shapefile and displays information about the dataset, such as the geometry type, number of features, and shapefile size.
    This validation ensures the selected file is a valid shapefile before import begins.
  10. When saving as an ArcGIS feature layer, you can assign Tags, provide a Summary, set the Sharing level, and assign Group sharing.
  11. Click Add. A feature layer is created.
    If the uploaded shapefile exceeds the data size or complexity thresholds, you can save it as an ArcGIS feature layer.
