Azure Event Hub
The Azure Event Hub output in ArcGIS Velocity allows you to send event data to Azure Event Hubs. Azure Event Hubs is a managed service hosted in the Azure cloud that can be used as a central message hub for bidirectional communication between Velocity and other IoT devices or applications.
Learn more about Azure Event Hubs
Examples
The following are example use cases for the output:
A logistics company configures an Azure Event Hub output to get enriched vehicle fleet information to various department systems.
A data analyst wants to send the results of their real-time analytic to Azure Event Hubs.
Usage notes
Keep the following in mind when working with the output:
Azure Event Hubs connection parameters can be obtained from Microsoft Azure Event Hubs in the Azure portal.
The following output data formats are available:
Delimited
JSON
GeoJSON
Esri JSON
Parameters
The following are the parameters for the output:
Parameter |
Description |
Data type |
Shared access key name |
The shared access key name for the Azure Event Hubs credentials. |
String |
Shared access key |
The shared access key for the Azure Event Hubs credentials. |
Password |
Event Hub endpoint |
The endpoint of the Azure Event Hubs, for example, |
String |
Event Hub entity path |
The path for the Azure Event Hubs entity, for example, |
String |
Output data format |
The format for outgoing messages. GeoJSON, Esri JSON, Delimited, and JSON formats are supported. |
String |
Write header row |
Specifies if the files write out the header row with field names. The default is false. |
Boolean |
Field delimiter |
The field delimiter used by the file to separate fields. The default is comma. |
String |
