Text Message
Use the Text Message output in ArcGIS Velocity to send a text message through an externally accessible SMTP server. You can configure the subject and message body of the text message to use attribute values. The output sends one text message for each feature it receives.
Example
The following is an example use case for the output:
An analyst configures a real-time analytic that filters events from a feed and sends a text message for features that meet the filter criteria.
Usage notes
Note the following when working with the output:
When using the Text Message output, consider the velocity of the data. Each record sent to the output generates a separate text message, which can quickly overload the capacity or rate-limiting settings of an SMTP server. Do not configure the Text Message output to send more messages than your SMTP server can handle.
You can send text messages to a single recipient or to multiple recipients using a comma-separated list.
You can configure text message recipients from an existing field or by entering phone numbers for each carrier.
If you configure recipients from a field, use the format number@carrier_domain. For example, for a phone number of (123) 456-7890 using the carrier AT&T, the corresponding recipient address is (123) 456-7890@txt.att.net.
If you enter recipients by carrier, provide the phone numbers for each carrier selected in the Carrier drop-down menu.
Phone numbers can be formatted as (123) 456-7890 or as 1234567890. Velocity removes all extraneous characters during processing.
Parameters
The following table describes the parameters for the output:
Parameter |
Description |
Data type |
SMTP server |
The SMTP server that sends the text message—for example, |
String |
SMTP server security |
The type of SMTP encryption to use on all outgoing messages. Options are as follows:
String |
Username |
The username for the SMTP server. |
String |
Password |
The password for the SMTP server. |
Password |
Sender's address |
The address that appears as the sender of the text message—for example, (123)456-7890@txt.att.net. |
Recipients (optional) |
The text message recipient or recipients. You can supply recipients from an attribute in the outgoing data or enter them manually when configuring the output. If you use an attribute from the data and send text messages to more than one recipient, use a comma-separated list. Single-recipient example: (123)456-7890@txt.att.net Multiple-recipient example: (123)456-7890@txt.att.net,(234)567-8901@txt.att.net,(345)678-9012@txt.att.net If you configure recipients manually, provide the phone numbers for each carrier selected from the drop-down menu. To enter multiple recipients, use a comma-separated list. Single-recipient example: (123)456-7890 with @txt.att.net selected from the Carrier drop-down menu. Multiple-recipient example: (123)456-7890,(234)567-8901,(345)678-9012 with @txt.att.net selected from the Carrier drop-down menu. |
Subject (optional) |
The subject of the text message. The subject can be configured in a single-line ArcGIS Arcade expression. |
Arcade Singleline Text |
Message body (optional) |
The body of the text message. The message body can be configured in a multiline Arcade expression. To reference a feature attribute value, enclose it in this token sequence: To use an Arcade expression, encode it in this token sequence: |
Arcade Multiline Text |
Considerations and limitations
Consider the following when using the output:
Use the Text Message output for incidents that occur infrequently.
The SMTP server must be accessible from the internet.
Major U.S. carriers are limiting or discontinuing email-to-text support, which can affect message delivery from this output:
Verizon Wireless is phasing out support for email-to-text messages sent to
Vtext.comaddresses, and some senders may lose access before the completion date. As a result, Verizon Wireless recipients may not receive text messages from this output.Carriers must support the email-to-text service to send or receive texts. As of June 2025, AT&T no longer supports email-to-text messages. You cannot send a text message to an AT&T customer from an email address, but you can still use SMS (text), MMS, and standard email services to communicate with them.
