Components of ArcGIS Velocity URLs
Uniform resource locators (URLs) are addresses used to identify websites. Some parts of Velocity URLs represent variable values that you replace with information specific to your site. Other parts of Velocity URLs are constants that remain the same for a particular type of website. For example, the ArcGIS Velocity Administrator Directory URL always contains the word admin.
In most cases, you can connect to Velocity URLs through a port number. You can also configure a reverse proxy. A reverse proxy can expose Velocity through a standard URL without a port number and under their own domain or web context name, so users do not need to connect directly to port 7143.
ArcGIS Velocity home page
Use the Velocity home page to sign in to Velocity.
If you access Velocity through a port number, the URL for the Velocity home page is in the following format:
https://velocity.example.com:7143/arcgis/home
The following table describes the components of the URL.
URL component Description
velocity The server name where Velocity is installed
example.com Your domain name
7143 Constant—The port through which the Velocity site communicates.
arcgis Constant
home Constant
If you access Velocity through a reverse proxy, the URL for the Velocity home page is in the following format:
https://reverseproxy.example.com/velocity/home
reverseproxy The server name where the reverse proxy is installed
velocity The web context name that you specify when configuring the reverse proxy
home Constant
ArcGIS Velocity Administrator directory
Connect to the ArcGIS Velocity Administrator directory to write administrative scripts for Velocity.
If you access Velocity through a port number, the URL for the Velocity Administrator directory is in the following format:
https://velocity.example.com:7143/arcgis/admin
7143 The port through which the Velocity site communicates. This port number is fixed and cannot be changed.
arcgis Constant
admin Constant
If you access Velocity through a reverse proxy, the URL for the Velocity Administrator directory is in the following format:
https://reverseproxy.example.com/velocity/admin
admin Constant
ArcGIS Velocity REST Services directory
Use the ArcGIS Velocity REST Services directory to view the REST services available on your server.
If you access Velocity through a port number, the URL for the REST Services directory is in the following format:
https://velocity.example.com:7143/arcgis/rest
arcgis Constant
rest Constant
If you access Velocity through a reverse proxy, the URL for the REST Services directory is in the following format:
https://reverseproxy.example.com/velocity/rest
rest Constant
