Configure network communication in the installation directory
ArcGIS Enterprise can be deployed on machines that have multiple network interface controller (NIC) cards or multiple entries (also called records) in a DNS name server. If you installed Velocity on a machine that contains more than one NIC card or multiple entries in a DNS name server, you must identify the IP address or hostname the server should use for network communication. You can do this either with the Create Site wizard or by editing a file in the installation directory.
To specify the interface that Velocity should use for network communication by editing a file in the installation directory, complete the following steps:
  1. Sign in to the machine on which Velocity is installed.
  2. Browse to the <Velocity installation directory>\framework\etc folder and open the file named hostname.properties, which is created during installation.
  3. By default, the file is populated. You can update the default value to the fully qualified domain name of the intended interface, for example: hostname=interface.example.com.
    For example, a machine can have two NIC cards or DNS entries (1 and 2), with interfaces that resolve to S1.mycompany.com and S2.mycompany.com. If you want Velocity to use the second interface for network communication, replace the existing hostname entry in the hostname.properties file with hostname=S2.mycompany.com.
    In some cases, such as when multiple interfaces share the same hostname, specify instead the IP address of the interface you want Velocity to use for network communication. Use the following syntax: hostname=<IP address>.
  4. Save and close the hostname.properties file.
  5. Restart the ArcGIS Velocity services.
  2. Browse to the <Velocity installation directory>/framework/etc folder and open the file named hostname.properties, which is created during installation.
