Detect Incidents
Available in real-time and big data analytics.
The Detect Incidents tool
evaluates features using a set of open conditions and optional close conditions and creates a unique incident for each continuous set of observations that satisfy the conditions.
Workflow diagram
Examples
The following are example use cases for the tool:
Each vehicle in a fleet sends its location and speed at regular intervals. If a vehicle's reported speed exceeds the posted speed limit for the location indicated, the Detect Incidents tool opens an incident. For each subsequent observation reported by the vehicle, if its speed continues to exceed the speed limit, the incident is maintained in an ongoing state. When the vehicle reports its speed within the posted speed limit, the incident is closed.
A pressure sensor on a pipeline reporting the active measured pressure at a valve indicates a pressure out of normal operating range. The Detect Incidents tool opens an incident, and the incident is maintained in an ongoing state as long as the sensor indicates the pressure is out of normal range. When the pressure returns to normal, the incident is closed.
A convoy of trucks is approaching a tunnel where vehicles carrying hazardous materials are prohibited. Each vehicle reports its location, and ArcGIS Velocity updates the incoming information for each vehicle based on the active manifest of its cargo. One of the trucks is carrying oxidizers that are considered hazardous. An incident is opened based on the truck's proximity to the tunnel and its cargo attributes. When the truck detours away from the tunnel, the incident is closed.
A delivery vehicle assigned to a specified route area goes outside the area for a period of time. An incident is opened when the vehicle exits the assigned area; the incident is closed when the vehicle reenters the area.
Usage notes
Keep the following in mind when working with the tool:
Feeds connected to the join input of stateful analytic tools require a designated
Track IDfield to improve analytic stability and performance. Any real-time analytic that uses a stateful tool, such as Detect Incidents, must include aTrack IDfield on the feed connected to the tool’s join input. If aTrack IDfield is not specified, the analytic will not start due to this missing requirement.The Open condition parameter is required, and the Close condition parameter is optional. If the Close condition parameter value is not explicitly set, the
NOTlogical operator of the Open condition parameter is used as the close condition.If the Spatial relationship option is set to Intersects, the implicit Close condition value is Disjoint.
If the Spatial relationship option is set to Enter or Exit, the implicit Close condition value is Exit or Enter, respectively.
In a real-time analytic, this tool operates in a stateful manner when Enter or Exit are used for the Spatial relationship option in the Open condition or Close condition parameters. While operating in a stateful manner, the tool can compare sequential observations to detect a change in state between observations. This tool runs in a stateless manner when using other spatial relationship options because it does not need to compare active to previous observations. Running in a stateless manner is much less resource intensive.
When operating in a stateful manner, the Detect Incidents tool maintains a state store of the active observation for each track ID. When a new observation is received, it is compared to the active observation of the same track ID, if present. If the new observation has a newer time stamp than the active observation in the state store, the active observation is replaced. If it has an identical time stamp to the active observation for the same track ID, the tool does not distinguish between the two observations. This means the tool does not replace the active observation in the state store with the new observation, the new observation is not added to the state store, and future observations for this track ID are compared to the active observation that remains in the state store until a new observation arrives with a later time stamp. The tool logs a warning when this occurs.
The tool has two inputs; however, the Join data parameter is only available if you choose Spatial relationship for the Open condition or Close condition parameters.
An ArcGIS Arcade expression can be configured for the Open condition or Close condition parameters.
In a real-time analytic, if the Close on expiration parameter is set to Yes, any open incidents are closed when the time set for Target time window expires. If it's set to No, any open incidents remain open. If the time set for Target time window expires, a new incident is created if the spatial relationship or attribute expression in the Open condition parameter is met.
For the Open condition parameter, if you choose Spatial relationship and use either the Enter or Exit spatial operator, you can check the First observation can trigger enter or First observation can trigger exit check box to indicate that the first target feature received or processed for each track ID can open an incident if it is inside any join feature in the case of Enter, or outside all join features in the case of Exit, despite having no previous target feature to which to compare the active target feature's location. The default is unchecked.
In a real-time analytic, set the Target time window parameter to the longest duration of time that an incident should remain open or longer. Observations older than this duration are deleted from memory to manage resources. It is recommended that you set the value higher than the longest expected incident duration. For example, if the longest an incident is expected to stay open is 20 hours, this value could be set to 24 hours to ensure that no incidents are closed prematurely.
The IncidentDuration value that is calculated for output incidents is in milliseconds.
If a feed is connected to the join port, incident detection is based on the changing features in both the target and join feeds.
When performing dynamic geofencing, the Join time window parameter must be set. If the join feed does not have a key field specified for the End time option and the last known observation for a join feature is older than this window, it is deleted from the tool's memory and excluded from the analysis. If the join feed has a key field specified for the End time option, the feature expires from the geofence store according to the value in the field that is the end time or at the close of the join time window, whichever comes first.
When dynamic geofencing is being performed, Arcade expressions are only valid for the target feature.
The tool does not require geometry, assuming no spatial condition is configured.
The following table outlines the available spatial relationship methods based on input and join geometry types:
Input and join geometry types
Contains
Crosses
Disjoint
Enter
Equals
Exit
Intersects
Near geodesic
Near planar
Overlaps
Touches
Within
Point and point
Point and polyline
Point and polygon
Polyline and point
Polyline and polyline
Polyline and polygon
Polygon and point
Polygon and polyline
Polygon and polygon
Parameters
The following are the parameters for the tool:
Parameter |
Description |
Data type |
Target data |
The data for which incidents are detected using the Open condition and Close condition parameters. |
Features |
Join data (optional) |
The data to be used with a spatial relationship in the Open condition or Close condition parameters. |
Features |
Open condition |
The set of conditions that define the start of an incident. This can include a spatial condition, time range, and a set of attribute expressions.
Note:When Disjoint or Exit is used as the spatial relationship for the Open condition parameter, the target features must be fully disjointed from any features from the Join Data parameter source for an incident to be opened. For all other spatial relationship options, the target feature only needs to satisfy the spatial relationship with any one of the features from the Join Data parameter source to open an incident. |
Parameters |
Close condition (optional) |
The set of conditions that define the end of an incident. As with the Open condition parameter, this can include a spatial condition, a time range, and a set of attribute expressions.
Note:When Disjoint or Exit is used as the spatial relationship for the Close condition parameter, the target features must be fully disjoint from any features from the Join data parameter value source for an incident to be opened. For all other spatial relationship options, the target feature only needs to satisfy the spatial relationship with any one of the features from the Join data parameter value source to open an incident. |
Parameters |
Return incidents only |
Yes—Returns observations that only relate to an incident. No—Returns all observations. |
Boolean |
Track ID fields |
Fields used to uniquely identify features to be processed. If the target feature layer has a track ID field specified, the Track ID value is automatically set. |
Fields |
Target time window (real-time analytics only) |
Observations older than this duration are deleted from memory to manage resources. Set this value to the longest duration that an incident should remain open or longer. It is recommended that you set this value higher than the longest expected incident time. |
String |
Join time window (real-time analytics only) |
The time window for the join feed (dynamic geofences). If the last known observation for a join feature is older than the time window specified, it is deleted and is not included in the analysis. If the join feed has a key field specified for the End time option, this parameter is optional. Note:This parameter is only available if both the target and join layers are feeds. |
String |
Close on expiration (real-time analytics only) |
Yes—Any open incident closes when the Target time window value expires. No—Any open incident remains open even if the Target time window value expires. Upon expiration of the Target time window value, a new incident is created if the spatial relationship or attribute expression is met. |
Boolean |
Output layer
The output layer has the schema of the incoming features in addition to the fields below:
Field name |
Description |
Field type |
IncidentId |
The unique identifier for the incident. |
String |
IncidentStatus |
The active status of the incident. The status can be Started, Ongoing, or Ended. |
String |
IncidentDuration |
The number of milliseconds the incident is open. |
Integer |
Consideration and limitation
Consider the following when working with the tool:
Velocity and Velocity tools expect source data dates and times to be stored in UTC. Arcade functions such as the ChangeTimeZone function can be used to convert data represented in a local time zone to UTC.
