Feature to Point
The Feature to Point tool
is used to dynamically produce a point from an input feature multipoint, polyline, polygon, or envelope geometry. The tool returns points generated from the centroids of the input features or placed within the input features.
Examples
The following are example use cases for the tool:
Calculate the centroid of a polygon feature to show the center of mass in real time. For example, a polygon feature representing a live hurricane can be reduced to a point centroid to show the generalized eye of the storm.
Reduce multipoint, polyline, polygon, or envelope features to a point to improve event record throughput and storage performance. Polygon or polyline features with thousands of vertices can impact the performance of real-time analytics in ArcGIS Velocity.
Usage notes
Keep the following in mind when working with the tool:
When working with the Feature to Point tool, the attributes of the input features are maintained in the output layer.
This tool requires geometry.
Parameter
The parameter for the Feature to Point tool is described in the table below.
Parameter |
Description |
Data type |
Point should be inside parent feature |
Specifies whether an output point is located within the input feature or at the centroid of the input feature.
If the Point should be inside parent feature parameter is not checked, the location of each output point is determined as follows:
If the Point should be inside parent feature parameter is checked, the location of the representative point of an input feature is contained by the input feature and determined as follows:
Boolean |
Consideration and limitation
The Feature to Point tool supports multipoint, polyline, polygon, and envelope geometry types as inputs. Point and tabular data are not supported.
Output layer
The Feature to Point tool output is a single part point feature layer that has all the attributes of the input features.
