Join Features
The Join Features tool
transfers attributes from the features in one feed, layer, or table to other features in the same feed or to those of another feed or dataset based on spatial, temporal, and attribute relationships, or some combination of the three. You can also calculate statistics for the joined features.
Workflow diagram
Examples
The following are example use cases for the tool:
An analyst has data on crime incidents in a city. To analyze and study the impact of these crimes, it is necessary to understand the relationship the crime locations have with various city jurisdictions, such as school districts, police boundaries, and neighborhoods. Using the Join Features tool, more information about each location can be appended to each crime, and the impact on various jurisdictions can be further analyzed.
When a shipping vessel from one feed enters a moving severe weather cell of another feed, enrich the vessel with attributes from the severe weather event feature.
Usage notes
Keep the following in mind when working with the tool:
You can join features based on a spatial relationship, a temporal relationship, an attribute relationship, or a combination of the three.
Option
Spatial relationship
The type of spatial relationship that determines whether features are joined to each other. The available relationships depend on the geometry type (point, line, or area) of the layers being joined, and include the following:
Intersects
Enter
Equals
Exit
Near planar
Near geodesic
Contains
Within
Touches
Crosses
Overlaps
A target feature must satisfy its spatial relationship against all join features when exit has been specified and there is more than one join feature. For any other spatial relationship and where there is more than one join feature, a target feature can satisfy its spatial relationship to any individual join feature.
Temporal relationship
The type of temporal relationship that determines whether features are joined to each other. The available relationships depend on the time type (instant or interval) of the layers being joined, and include the following:
Meets
Met by
Overlaps
Overlapped by
During
Contains
Equals
Finishes
Finished by
Starts
Started by
Intersects
Near
Attribute relationship
The attribute relationship determines whether features are joined to each other. Features are matched when the field values in the join layer are equal to field values in the target layer.
If multiple features match the same target feature, you can determine whether all the matching features are joined (Join one to many) or whether all the matching features are summarized together (Join one to one) using one of the following options:
Join one to one—This option summarizes all the matching join features to each feature in the target layer. Joined features are aggregated in the output layer to correspond with the join field. The count of joined features are added, as well as other statistics, such as Sum, Minimum, Maximum, Range, Mean, Variance, and Standard deviation. Summary statistics can only be calculated if a Join one to one operation is specified.
Join one to many—This option joins all matching features in the join layer to the target layer. The resulting layer contains multiple records of the target feature.
When the Join operation parameter is set to Join one to many, there can be more than one row in the output feature class for each target feature.
Examples of a one-to-many and one-to-one join are shown. In this example, the one-to-one join only includes the count; additional statistics that can be calculated are shown below. When configuring the Join Features tool in a one-to-one join, you can choose the only retain features that are joined or retain all features regardless of join results option. These options are described below.
If you choose only retain features that are joined, features that successfully joined with a feature from the join dataset are present in the output.
If you choose retain all features regardless of join results, all features from the target dataset exist in the output, regardless of whether there were any joined attributes.
When retaining all features, if a feature is retained but there was no join for that feature, the
COUNTvalue is zero and any summary field attribute values are null.This option is only available for one-to-one joins.
If target and join features are in different coordinate systems, the coordinate systems of the target feature are used.
If a join feature has a spatial relationship with multiple target features, it is counted as many times as it is matched with the target feature. For example, if a point is within three polygons, the point is counted three times, once for each polygon.
When Spatial relationship is set to Near geodesic or Near planar, either the target layer must be projected or the output coordinate system must be set to a projected coordinate system.
You can optionally build an expression to join features. If you specify an expression, only features that meet the condition are used. For example, you can only join target features from the
Magnitudefield if it is greater than the join feature, with a field namedExplosion, using the expression$target["Magnitude"] > $join["Explosion"].When Spatial relationship is set to enter or exit in a real-time analytic, the following are true:
The tool operates in a stateful manner, which enables it to compare sequential observations to one another to detect a change in state, for example, whether the active condition is different from that of the previous observation. With other spatial relationships in real-time analytics, the tool does not need to compare any observations with the previous observation, so it can run in a stateless manner, which is less resource intensive.
When operating in a stateful manner, the Join Features tool maintains a state store of the active observation for each track ID. When a new observation arrives, it is compared to the active observation of the same track ID, if present. If the new observation has a newer time stamp than the active observation in the state store, it replaces the active observation. If it has an identical time stamp to the active observation for the same track ID, the tool cannot distinguish between the two observations. This means the tool does not replace the active observation in the state store with the new observation, the new observation is not added to the state store, and future observations for this track ID are compared to the active observation that remained in the state store until a new observation arrives with a later time stamp. The tool logs a warning that this occurred.
Checking First observation can trigger enter or First observation can trigger exit indicates that the first target feature received satisfies the filter condition if it is inside (in the case of enter) or outside (in the case of exit) any join feature, despite having no previous target feature to compare the active target feature's location to. The default is false (not checked).
The Target Time Window parameter should be set to the longest anticipated interval between observations for any given track at a minimum. Observations older than this duration are deleted from memory to manage resources.
- It is recommended that this value exceeds the longest anticipated interval, as a value that is too short can result in deleting records from the feature store before new observations arrive. This means the historical information is deleted from the feature store and the next feature is treated as the initial observation. In other words, observations would never enter or exit the Join Features tool because the analytic would have no knowledge of the previous observation.
In dynamic geofencing, the Join Time Window parameter must be set. If the join feed does not have a field tagged as
END_TIMEand the last known observation for a join feature is older than this window, it is deleted from the tool's memory and is not included in the analysis. If the join feed has a field tagged asEND_TIME, the feature expires from the geofence store according to the value in the field tagged asEND_TIMEor when the join time window is closed, whichever comes first.Statistics are calculated for only those features that meet the specified spatial, temporal, or attribute relationship used in the Join one to one operation. You can calculate numeric and string statistics.
This tool does not require geometry, assuming no spatial join is configured.
Parameters
The following are the parameters for the tool:
Parameter |
Description |
Data type |
Target layer |
The target layer containing the features to process. |
Features |
Join layer |
The layer whose features are joined to those of the target layer. |
Features |
Join operation |
Specifies whether the join is one-to-one or one-to-many.
String |
Retain all features |
Specifies whether only the features in successful joins are retained or all features are retained regardless of whether there was a successful join for those features. This option is only available for one-to-one joins. For one-to-many joins, this option is not available and only features with successful joins are returned. If all features are retained, for features with no join, the count is zero and any summary field values are null. |
String |
Spatial relationship |
Specifies the criteria used to spatially join features. Different spatial criteria are available if the Spatial parameter is checked.
String |
Spatial near distance |
Join features within this specified distance of a target feature to be considered for the spatial join. A spatial near distance is only valid when the spatial relationship is set to Near geodesic or Near planar. |
Linear Unit |
Temporal relationship |
Specifies the time criteria used to match features. This parameter is available if Temporal is checked. Different temporal criteria are available depending on the time features set for the Instant or Interval parameters.
String |
Temporal near distance |
The amount of time between events. Joins occur between events that occur within the time window of each other. This parameter is available if Temporal relationship is set to Near. |
Time Unit |
Attribute relationship |
Joins features based on values in an attribute field. Specify which attribute field from the target layer matches an attribute field from the join layer. This parameter is available if Attribute is checked.
String |
Summary fields |
Specifies the statistics to be calculated on specified fields from the join features. Statistics are calculated for one-to-one joins. Different statistics are available depending on whether the specified field is a string, numeric, or date field.
String |
Join condition |
Applies a condition to specified fields. Only features with fields that meet these conditions are joined. For example, you can apply a join to features in which the |
String |
First observation can trigger enter/exit |
Specifies whether the first target feature received satisfies the spatial relationship condition if it is inside any join feature in the case of enter or outside all join features in the case of exit, despite having no previous target feature to which to compare the active target feature's location. The default is false (not checked). |
Boolean |
Change geometry of target feature to geometry of join feature |
Changes the geometry of the target feature to the geometry of the join feature. For example, if the target feature is a point and the join feature it is joined with is a polygon, the target feature assumes the polygon geometry of the join feature. The default is false. If the target feature does not have a geometry, it assumes the geometry of the join feature it is joined with. If the target feature has a geometry and the join feature it is joined with does not have a geometry, the target feature loses its geometry and becomes tabular. Note:This parameter is not valid when Retain all features is set to true. Output features cannot have different geometries. |
Boolean |
Target Time window |
This parameter should be set to the longest anticipated interval between observations for any given track at a minimum. Observations older than this duration are deleted from the memory to manage resources. This parameter is only valid when Spatial relationship is set to enter or exit. |
String |
Join Time window |
The time window for the join feed (dynamic geofencing). If the last known observation for a join feature is older than the time window specified, it is deleted and is not included in the analysis. If the join feed has a field tagged as |
String |
Considerations and limitations
Consider the following when working with the tool:
Summary statistics are only calculated if the Join one to one operation is specified.
The
COUNTfield name represents the number of joined features for a one-to-one join. If theCOUNTfield name exists in the target schema, the field is calledjoin_COUNT. If you're performing multiple consecutive joins, the field names areCOUNT,join_COUNT,join_COUNT1,join_COUNT2, and so on. This is done to avoid field name conflicts.
