Merge
Available in real-time and big data analytics.
The Merge tool copies two layers to create a single output layer. Both layers must have the same feature geometry type (tabular, point, line, or polygon) and at least one matching field name and type. If time is enabled on one layer, the other layer must also be time enabled and have the same time type (instant or interval).
Workflow diagram
Merge tool workflow diagram
Example
A city wants to restore the area around a river by developing a new park. The park must be near the river but not in proximity to existing parks or hazardous facilities. Buffers around the existing parks and hazardous facilities can be merged into a single layer using the Merge tool to create an exclusion zone where a new park should not be developed.
Usage notes
Keep the following in mind when working with the tool:
  • Two inputs of the same feature geometry type are required (point, line, polygon, or tabular).
  • The two inputs must have at least one matching field name and type to be merged.
  • This tool can merge inputs with the same schema with fields in a different order. It is recommended you merge inputs with fields in the same order.
  • When merging fields with the same name but different nullable values (nullable can be true or false), the resulting field is nullable.
  • This tool does not require geometry.
Parameters
The following are the parameters for the tool:
Parameter
Data type
Input layer
The point, line, or polygon features or table to merge with the merge layer. The input layer must contain the same feature type and schema as the merge layer.
Features
Merge with
The point, line, or polygon features or table to merge with the input layer. The merge layer must contain the same feature type and schema as the input layer.
Features
Output layer
The output layer retains the same schema as the input and merge layers. The field type must be the same for any matching field name. If a field is present in one schema but not in the other, it is added to the output schema, with a null value configured if a record does not have a value.
