Reconstruct Tracks
Tool icon Available in big data analytics.
The Reconstruct Tracks tool connects time-sequential points to tracks and summarizes features in the track. Tracks are identified by one or more track fields. The resulting layer displays the track as a line or an area, the count of features in a track that have been summarized, and any additional statistics that have been specified.
Workflow diagram
Reconstruct Tracks workflow diagram
Example
Hurricanes are some of the most violent types of storms that occur in the United States. To assess insurance rates, you want to know the paths that hurricanes have traveled to determine locations that have historically had high property damage and financial loss from hurricanes. You have access to hurricane location data across the United States in a single dataset, with a time stamp at each location. You want to summarize all the information to see a summary of values for all hurricanes. You can summarize your data using the hurricane tracks identifier to determine the statistics for each hurricane.
Usage notes
Keep the following in mind when working with the Reconstruct Tracks tool:
  • Inputs must be point or area layers with time-enabled features of type instant. Any features that do not have time are not included in the output tracks.
  • The Reconstruct Tracks tool runs on point or area features. The input layer must be time enabled with features that represent an instant in time.
  • For linear results, only tracks that contain more than one point are returned. If you apply a buffer, all features are returned.
  • Input features consist of time-enabled features that represent an instant in time. Results are line or area features that represent an interval in time. The start and end of the interval are determined by the time at the first and last features in a track.
    The input features with two distinct tracks (green and magenta) that have time type instant (left) and the resulting tracks (right) or time type interval are shown.
  • The most basic calculation in a track is a count of the number of features that have been summarized. Statistics (Count, Sum, Sum of squares, Minimum, Maximum, Range, Mean, Standard deviation, and Variance) can also be calculated on numerical fields, and statistics (Count, Count Distinct, and Any) can be calculated on string fields. The string statistic any returns a sample string from each track. The statistics are calculated on each track separately.
  • The field or fields used to identify tracks are returned in the results.
  • You can specify one or more fields to identify tracks. Tracks are represented by the unique combination of one or more track fields. For example, if the fields flightID and Destination are used as track identifiers, the features ID007, Solden, and ID007, Tokoyo would be in two separate tracks, since they have different Destination field values.
  • You can optionally apply a buffer to your input features. When you apply a buffer, resulting tracks are area features.
    Input points with a buffer applied are reconstructed into tracks.
  • Buffers are created using a field value or buffer expression, both of which can be configured using an Arcade expression. You can apply a track-aware expression. For example, you could buffer the current feature by the mean of the field wind_speed for the previous three features in a track with the equation mean($track.field["wind_speed].history(-4, -1)). When buffering input features, each input feature is buffered. Then a convex hull is generated to create an area track.
  • When buffering input features, each input feature is buffered. Then a convex hull is generated to create an area track.
    An example of input points (green), intermediate buffer for visualization (blue hatching), and the resulting polygonal track (blue) is shown.
  • By default, tracks are created using a geodesic method. The method is applied to the following two components of the analysis:
    • Tracks crossing the international date line—When using the geodesic method, input layers that cross the international date line have tracks that correctly cross the international date line. This is the default. Your input layer must be set to a spatial reference that supports wrapping around the international date line, such as a global projection like World Cylindrical Equal Area.
    • Buffers—Input features can optionally be buffered. To learn more about when to apply a geodesic or planar buffer, refer to the Create Buffers tool.
  • There are two ways to split tracks:
    • Apply a time split—Applying a time split breaks any track apart when input data is further apart than the specified time. For example, if you had five features with the same track identifier and the times of [01:00, 02:00, 03:30, 06:00, 06:30] and set a time split of two hours, any features that are measured more than two hours apart are split. In this example, the result would be a track with [01:00, 02:00, 03:30] and [06:00, 06:30], because the difference between 03:30 and 6:00 is greater than two hours.
    • Apply a distance split—Applying a distance split breaks any track apart when input data is farther apart than the specified distance. For example, if you set a distance split of five kilometers and sequential features greater than five kilometers apart would be part of a different track, the split options would be as follows:
      Five examples of input points (green) with varying time and distance splits are shown.
      Split option
      Option 1
      Input points with the same ID with a time (instant) and location.
      Option 2
      Example with no time split and no distance split.
      Option 3
      Example with a time split of two hours. Any features greater than two hours apart (1:30 and 4:00) are split into separate tracks.
      Option 4
      Example with a distance split of two kilometers. Any features greater than two kilometers apart (the features at 11:30 and 12:00) are split into separate tracks.
      Option 5
      Example with a distance split of two kilometers and time split of two hours. Any features greater than two kilometers apart (the features at 11:30 and 12:00) or two hours apart (1:30 and 4:00) are split into separate tracks.
  • Output tracks return the fields used as track identifiers (TRACK_ID), the count of features in a track (COUNT), the start and end time of each track (StartTime and EndTime), the duration of the track in milliseconds (TRACK_DURATION) and any other optional statistics.
  • Additional statistics can be calculated using the Summary fields parameter. The summary fields statistics available depend on the field type you are summarizing. A string attribute field can use the statistics Any, Count, and Count distinct. A numeric attribute field can use the statistics Any, Count, Count distinct, Sum, Sum of squares, Min, Max, Range, Variance, and Standard deviation. A date attribute field can use the statistics Any, Count, Min, Max, and Range.
Parameters
The following are the parameters for the Reconstruct Tracks tool:
Parameter
Data type
Input Layer
The point features for which either journeys or dwell locations are calculated.
Features
Split distance
A distance used to split tracks. Any features in the input dataset that are in the same track and are greater than this distance apart are split into a new track. To avoid splitting the tracks, leave this parameter empty.
String
Split duration
A time duration used to split tracks. Any features in the input dataset that are in the same track and are greater than this time apart are split into a new track. To avoid splitting the tracks based on time, leave this parameter empty.
String
Track ID field
You must choose the field or fields to uniquely identify features that you want processed. If the TRACK_ID field has been set in the input layer, this parameter is automatically populated.
String
Summary fields
The statistics that are calculated for specified fields. Different statistics are available depending on whether the specified field is a string, numeric, or date field.
  • Any—This is a sample string from a field of type string.
  • Count—Calculates the number of nonnull values. It can be used on numeric fields or strings. The count of [null, 0, 2] is 2.
  • Count Distinct—Calculates the number of distinct, non-null values. It can be used on numeric fields or strings. The count distinct result of [null, 4, 3, 4] is 2.
  • Sum—The sum of numeric values in a field. The sum of [null, 1, 3] is 4.
  • Sum of Squares—The sum, over all observations, of the squared differences of each observation from the overall mean. The sum of squares of [null, 2.2, 3.1, 4.7] is 3.206.
  • Min—The minimum value of a numeric field. The minimum of [0, 2, null] is 0.
  • Max—The maximum value of a numeric field. The maximum value of [0, 2, null] is 2.
  • Mean—The mean of numeric values. The mean of [0,2, null] is 1.
  • Range—The range of a numeric field. This is calculated as the minimum value subtracted from the maximum value. The range of [0, null, 1] is 1. The range of [null, 4] is 0.
  • Variance—The variance of a numeric field in a track. The variance of [1] is null. The variance of [null, 1,1,1] is 1.
  • Standard Deviation—The standard deviation of a numeric field. The standard deviation of [1] is null. The standard deviation of [null, 1,1,1] is 1.
String
Buffer expression
Optional field used to buffer the input features. Field values are applied in the units of the spatial reference of the input unless the input is using a geographic coordinate system, in which case, they are in meters.
Buffering the input features by a field value is useful for producing output polygonal tracks where the width of the track indicates a measure of the event at that location—for example, polygonal hurricane tracks indicating the relative wind speed in different areas.
String
Method
Whether to use a Planar approach or a Geodesic approach when splitting track lines by a distance value.
If Planar is selected, the input points must be projected. The Project tool can be used to project the input points before running the Reconstruct Tracks tool.
String
Output layer
The output layer contains the TRACK_ID field of the input observations as well as the attributes specified in the table below.
Field name
Field type
TRACK_ID
The TRACK_ID key field used for processing
Any
COUNT
The number of observations used to construct the track
Float64
TRACK_DURATION
The duration of the track in milliseconds (EndTime- StartTime)
Float64
StartTime
The StartTime of the track
Date
EndTime
The EndTime of the track
Date
