Route by Expressions
The Route by Expressions tool routes a record to one of the several destinations or outputs based on specified conditions. This tool evaluates a record against sequential ArcGIS Arcade expressions to a record similar to the if-else statement in a programming language. Each record is evaluated by the specified conditions. Records that a condition evaluates as true are retained and sent to that output.
Example
The following is an example use case for the tool:
A GIS analyst uses the Route by Expressions tool in a real-time analytic to route incoming records to different processing paths based on the value of the $feature.VehicleType condition. For example, records with VehicleType == "Airplane" are routed to an airplane-specific output, while those with VehicleType == "Train" or VehicleType == "Automobile" follow their respective paths. Records that do not match any defined condition are discarded if the Otherwise parameter is not turned on.
Usage notes
Keep the following in mind when working with the tool:
  • This tool has a single input pipeline and multiple variable quantity pipeline outlets.
  • The maximum number of routes that can be connected is 10.
  • This tool requires at least one conditional statement to work.
  • This tool routes a record by defining Arcade expressions.
  • This tool prioritizes one record at a time, in serial order, from the top (first) to the bottom (last).
  • If a record does not meet any of the specified conditions, and the Otherwise parameter is not specified, the record is dropped and is not processed.
  • This tool does not require geometry.
Parameters
The following are the parameters for the tool:
Parameter
Data type
Expression
An attribute expression that evaluates records to filter the incoming data. The expression is configured in the Arcade expression builder, accessed by clicking the Configure an Arcade expression option. All records are evaluated. Records that result true are retained, and false results are discarded.
String
(Arcade expression)
Otherwise
If the Otherwise parameter is turned on, unmatched records are processed. If the Otherwise parameter is turned off, those unmatched records are discarded.
Boolean
Output pipelines
The Route by Expressions tool does not alter incoming records; the output layer contains the same fields and attribute values as the incoming records.
