Split by Attributes
Available in real-time and big data analytics.
The Split by Attributes tool
receives an input table, identifies a string field and delimiter, and produces an output table with the rows split by that field’s delimiter.
Examples
Incoming data is not always structured for immediate analysis. Some data providers send multiple values in a single field, such as a list of units, lanes, circuits, or zones. The Split by Attributes tool creates a separate record for each value in the selected field, allowing each value to be analyzed, routed, or summarized individually.
The following are example use cases for the tool:
An emergency dispatch feed includes responding units in a single field, such as
E12,L3,M5. The tool can split the field to create one record per unit for tracking response workload.A utility outage alert includes affected circuits in a single field, such as
CIR-104;CIR-991;CIR-120. The tool can split the field to create one record per circuit for routing or assignment to circuit owners.A weather or hazard notification includes affected zones in a single field, such as
ZoneA/ZoneB/ZoneC. The tool can split the field to create one record per zone for zone-based alerting or analysis.
Usage notes
Note the following when working with the tool:
This tool only accepts string fields.
The delimiter field allows only one character.
Example characters include
,:;/and|. A single space is also supported. Use\tto represent tab characters.The characters
\“‘and`are not supported.
Use the Calculate Field tool with the
Trim()function in ArcGIS Arcade to remove leading and trailing spaces.If an incoming field is null or empty, the tool returns a single record with a null value.
How the tool works
Given the input table below with , as the specified delimiter, with the following fields:
The Split by Attributes tool provides the following output:
If delimiters occur sequentially, the tool returns rows for each occurrence between delimiters with an empty string for the field. For example, the following input uses , as the specified delimiter:
This input results in the following output:
Parameters
The following table describes the parameters for the tool:
Parameter |
Explanation |
Data type |
Input layer |
The real-time features to split. |
Features |
Field name |
The field that contains the delimited string to process. Only string fields are available to choose from. If no string fields are available in the Input layer parameter, a validation error occurs. |
String |
Delimiter |
The character used to split the string field into multiple values. |
String |
Output layer
The output layer usually contains more rows than the input layer because the tool splits rows based on the selected field and delimiter. Rows with multiple delimited values create one output row for each split value, and rows without the delimiter create one output row.
All input fields and geometry are preserved. Each child row retains the same attributes and geometry from the parent row except the selected field that contains only one split value per row.
