Amazon Web Services (AWS) IoT
The Amazon Web Services (AWS) IoT output type in ArcGIS Velocity sends event data to the AWS Internet of Things (IoT). AWS IoT is a managed cloud service that provides a solution for connected devices to interact with AWS cloud services, as well as other IoT devices.
Learn more about AWS IoT
Examples
The following are example use cases for the output:
  • A data analyst wants to send the results of their big data analytic to AWS IoT Hub.
  • A logistics company configures an AWS IoT output to send enriched vehicle fleet information to various department systems.
Usage note
AWS IoT connection parameters can be obtained from the AWS IoT web interface.
Parameters
The following are the parameters for the output:
Parameter
Data type
Endpoint
The endpoint for the AWS IoT broker.
String
Access key ID
The access key for the AWS IoT credentials.
String
Secret access key
The secret access key for the AWS IoT credentials.
Password
Topic
The topic over which event messages are streamed.
String
Quality of Service level
Specifies the Quality of Service (QoS) level for a connection to the AWS IoT message broker. The AWS IoT message broker supports QoS levels 0 and 1. For more information, refer to the QoS options in the AWS documentation.
  • 0—At most once. The message is sent once and the client and broker take no additional steps to acknowledge delivery (fire and forget).
  • 1—At least once. The message is retried by the sender multiple times until acknowledgment is received (acknowledged delivery).
Integer
Session token (optional)
The session token for the AWS IoT broker.
String
Configure message from an Arcade expression
The message constructed using an Arcade expression.
Arcade expression
Send feature to AWS IoT in specified format
The feature sent to AWS IoT in a specified format. When you choose this parameter, the Data format option appears. The default data format is Delimited. Other supported formats include Esri JSON, GeoJSON, and JSON.
Data format type
Message delimiter
The message delimiter used by the file to separate messages. The default is a newline character \\n.
String
