Azure Blob Store
The Microsoft Azure Blob Store output in ArcGIS Velocity allows you to write output features to files in an Azure Blob Store.
Example
The following is an example use case for the output:
An example use of this output could be that after performing analysis in a big data analytic, a researcher wants to write the output spatial or tabular features to files in an Azure Blob Store.
Usage notes
Keep the following in mind when working with the output:
The Dataset parameter specifies the folder name where Velocity writes to an Azure Blob Store. This folder contains one or more files, depending on the output size.
The account key is encrypted the first time an analytic is saved and stored in an encrypted state.
When specifying the folder path, use forward slash (/) symbols.
This output is only available in big data analytics.
Any folder specified in the Folder path parameter must exist and contain content before data can be exported to it.
The following output data formats are available:
Delimited
JSON
GeoJSON
EsriJSON
Parquet
Shapefile
Data exported in parquet format includes the
SHAPEandDATEfields. TheSHAPEfield contains geometry in well-known text (WKT) format. TheDATEfield is provided if the data includes theSTART_TIMEkey field.Data exported in delimited format includes a
SHAPEfield with geometry in EsriJSON format.Data exported in the JSON format provides geometry in the EsriJSON format.
If the Error If Exists option is chosen for the Write mode parameter, the big data analytic fails to run if a dataset with the same name already exists at the specified folder path.
Parameters
The following are the parameters for the output:
Parameter |
Description |
Data type |
Account key |
The account access key for the Azure Blob Store. Velocity uses the account access key to write data to the Azure Blob Store. The account access key is encrypted the first time an analytic is saved and stored in an encrypted state. |
String |
Account name |
The name of the Azure storage account that contains the Azure Blob Store containers. |
String |
Endpoint suffix |
The endpoint suffix for accessing the Azure Blob Store is |
String |
Container name |
The name of the Azure Blob Store container where the files are written. |
String |
Folder path |
The folder path specifies the location where the output dataset folder and files are written. The specified folder must exist and have content before data can be exported to it.
String |
Dataset |
The folder that contains the output file or files. Files written to this folder are automatically named and divided into multiple files as necessary. You must not include file extensions in the dataset name. |
String |
Write mode |
The write modes that can be used to write features to files in the Azure Blob Store. The following are the available write modes:
String |
Output data format |
The format for outgoing messages. The following formats are supported:
String |
Write header row |
Specifies if the files write out the header row with field names. The default is false. |
Boolean |
Field delimiter |
The field delimiter used by the file to separate fields. The default is comma. |
String |
