Azure Event Hub
The Azure Event Hub output in ArcGIS Velocity allows you to send event data to Azure Event Hubs. Azure Event Hubs is a managed service hosted in the Azure cloud that can be used as a central message hub for bidirectional communication between Velocity and other IoT devices or applications.
Learn more about Azure Event Hubs
Examples
The following are example use cases for the output:
  • A logistics company configures an Azure Event Hub output to get enriched vehicle fleet information to various department systems.
  • A data analyst wants to send the results of their big data analytic to Azure Event Hubs.
Usage notes
Keep the following in mind when working with the output:
  • Azure Event Hubs connection parameters can be obtained from Microsoft Azure Event Hubs in the Azure portal.
  • The following output data formats are available:
    • Delimited
    • JSON
    • GeoJSON
    • Esri JSON
Parameters
The following are the parameters for the output:
Parameter
Data type
Shared access key name
The shared access key name for the Azure Event Hubs credentials.
String
Shared access key
The shared access key for the Azure Event Hubs credentials.
Password
Event Hub endpoint
The endpoint of the Azure Event Hubs, for example, iothub-ns-streetlight-010101-0f024610d9.
String
Event Hub entity path
The path for the Azure Event Hubs entity, for example, Streetlights-IoT-Hub. This is also referred to as the namespace.
String
Output data format
The format for outgoing messages. GeoJSON, Esri JSON, Delimited, and JSON formats are supported.
String
Write header row
Specifies if the files write out the header row with field names. The default is false.
Boolean
Field delimiter
The field delimiter used by the file to separate fields. The default is comma.
String
Message delimiter
The message delimiter used by the file to separate messages. The default is a newline character \\n.
String
