UDP (Client)
The UDP (Client) output sends data from event records to a UDP server using a UDP socket connection. Data can be formatted as delimited text or JSON. UDP datagrams (messages) are sent via unicast.
Example
The following is an example use case for the output:
A weather station sends real-time temperature and humidity data to a central server using UDP in JSON format.
Usage notes
Keep the following in mind when working with the output:
ArcGIS Velocity supports multiple output data formats when using the UDP (Client) output. The output formats include JSON, GeoJSON, EsriJSON, and delimited text.
It is recommended that data from different feeds use their own output connectors and ports.
When output is formatted as delimited text, if you want a header row, you must select the Write header row option.
A field delimiter must be specified when formatting data as delimited text. Common delimiters are comma, semicolon, and pipe characters.
Parameters
The following are the parameters for the output:
Parameter |
Description |
Data type |
Host (Required) |
The host address that UDP datagrams (messages) publishes to using a UDP socket. The default is localhost, but any accessible hostname or IP address can be specified. |
String |
Port (Required) |
The server port used to establish a UDP socket connection—for example, 5005. |
Integer |
Output data format (Required) |
The format of the output data. The available options are EsriJSON, GeoJSON, Delimited text, and JSON. |
Output data format type |
