Azure Cosmos DB
The Azure Cosmos DB data source type in ArcGIS Velocity reads records from database collections stored in Azure Cosmos DB.
Example
A researcher wants to load data from a database collection stored in Azure Cosmos DB into Velocity to perform analysis.
Usage notes
Consider the following when using the data source:
The master key is encrypted the first time the analytic is saved and is stored in an encrypted state.
A where clause can be specified to restrict the records loaded from the Azure Cosmos DB container collection.
Analytic run time variables can be specified in the Where clause parameter to only load new features from the Azure Cosmos DB container collection for each run.
Parameters
The following are the parameters for the data source:
Parameter |
Description |
Data type |
Endpoint |
The endpoint URL for Azure Cosmos DB, for example, |
String |
Master key |
The primary key for Azure Cosmos DB. |
String |
Database |
The name of the Azure Cosmos DB container that contains the collection of data to read. |
String |
Collection |
The name of the Azure Cosmos DB collection in the specified container that contains the data. |
String |
Where clause (optional) |
Restrict the features loaded from the Azure Cosmos DB container collection. Use a simple query format. For example, if a numeric field named In the Azure Cosmos DB interface, these queries are in the form When querying string fields, use single quotation marks around text that is part of the query, for example, Analytic run time variables can be specified to only load new features for each run in a recurring big data analytic. These variables are replaced with the relevant analytic scheduled start times for querying ISO 8601 string fields in Azure Cosmos DB. The available analytic run time variables available are For example, you can specify a where clause as shown below in which the analytic was started June 6, 2021, at 12:01:01 UTC.
String |
Considerations and limitations
When specifying a where clause to filter string values, wrap text values in single quotation marks.
When specifying date fields, only the following configurations are supported for this data source:
Epoch seconds such as
1616673883Epoch milliseconds such as
1616673883000ISO 8601 datetime format with no time zone such as
2021-03-25T12:05:34ISO 8601 datetime format with a time zone such as
2021-03-25T12:05:34+0000String dates in the format (milliseconds are optional)
yyyy-MM-dd HH:mm:ss[.fffffffff]such as2021-03-25 12:05:34 or 2021-03-25 12:05:34.435
