Raven Connected
The Raven Connected feed type in ArcGIS Velocity connects to Raven Connected and receives real-time telematics data for your fleet. Raven Connected is an in-vehicle safety and fleet intelligence platform that provides telematics data streams with insight into vehicle behavior and operational conditions. You can use this data for road safety monitoring and situational awareness.
Examples
The following are example use cases for the feed:
  • Use Raven Connected data to visualize live vehicle positions in web apps and monitor conditions such as sudden stops, abnormal vehicle behavior, and incidents along roadways.
  • Use Raven Connected data to ingest GPS location, vehicle state, driving information, and video telematics to support road incident awareness with spatial, operational, and visual context on location and timing of events.
Usage notes
Note the following when working with the feed:
  • You can access real-time telematics data for your fleet in the Raven Connected app.
  • After generating the API key, copy the API key and provide it along with the feed item URL to Raven Connected so they can start sending data to the URL endpoint.
  • Velocity automatically handles the data schema. You cannot add new fields because the schema is predetermined from data provided by Raven Connected.
  • Raven Connected data is in JSON format, and Velocity automatically handles the Location parameter when identifying key fields.
  • Velocity automatically handles the Track ID and Date and time parameters when identifying the key fields.
Parameters
The following are the parameters for the feed:
Parameters
Data type
API Key
The API key required to authenticate and connect to Raven Connected.
Generate the API key using the Generate API Key option. After generating the API key, use the show icon to view it and the copy icon to copy it. Provide the API key with the feed item URL to Raven Connected so they can start sending data to the URL endpoint.
Learn more about getting started with the Raven API
Raven Connected format type
Additional logging (optional)
Specify whether you want to log raw HTTP requests and responses issued by Velocity to Raven Connected.
Turn this parameter on for troubleshooting and turn it off when troubleshooting is complete. After you turn it on, start the feed. Debug level logs are available on the feed logs page. Contact Esri Technical Support for troubleshooting help.
Boolean
