Share feeds
Feeds created in ArcGIS Velocity can be shared with other users in your organization and to groups.
Other users can add shared feeds to web maps, web apps, ArcGIS Pro, and other ArcGIS mapping apps. Additionally, other Velocity users in your organization can create real-time analytics using shared feeds.
Share a feed
Feeds created in Velocity can be shared with others using Velocity and ArcGIS Online.
Share a feed in Velocity
To share a feed in Velocity, complete the following steps:
  1. Start Velocity and sign in.
  2. On the Feeds page, open an existing feed to access the feed Details page.
  3. Click Share.
  4. In the Share pop-up, share the feed with your organization or specific groups.
  5. Optionally, turn on the Share all properties option Toggle button to share all properties with other users.
    If you do not share all properties, sensitive information such as the username, password, secret keys, headers, POST body, URLs, and more are not shared. If you share properties, values like username, headers, URLs, and POST body are shared. Properties like password and secret keys are never shared. This ensures that you do not unintentionally share sensitive information, such as credentials and API keys with other users.
  6. Optionally, turn on the Enable feed writing to all users who the feed is shared with option Toggle button to extend feed writing permissions to other users.
    This option is turned off by default and is only available for HTTP Receiver and gRPC feeds configured with ArcGIS authentication. When turned on, any ArcGIS users that have the feed shared with them can send data to this feed when they provide a token with the request.
  7. Click Apply to share the feed.
Other users in your organization can now search for and browse the shared feed.
Share a feed in ArcGIS Online
To share a feed in ArcGIS Online, complete the following steps:
  1. Sign in to ArcGIS Online.
  2. Go to the Content page.
  3. Check the check box next to the feed you want to share, and click Share.
  5. Click Save to share the feed.
Use a shared feed
If a feed is shared, you have several options available for using the shared feed in ArcGIS Velocity and ArcGIS Online.
Add a shared feed to a real-time analytic in ArcGIS Velocity
To add a shared feed when creating a real-time analytic or editing an existing real-time analytic, complete the following steps:
The feed must be shared by its owner.
  1. As the real-time analytic publisher, choose the Existing feed option when selecting an input feed.
  2. As the real-time analytic publisher, in the content browser, browse to the My Organization page and search for or browse to the shared feed.
Open a shared feed in ArcGIS Online
Feeds can be shared with a group or the organization. When a feed is shared, you can access it in ArcGIS Online by searching, browsing, or viewing group content. You can then use the Open in Velocity option on the item details page to open the feed details page in Velocity.
From the feed details page you can create a real-time analytic that can consume data from the shared feed.
Open a shared feed using a URL
To share a feed with others using a simple URL, complete the following steps as the owner:
  1. Share the feed with the desired sharing level or groups.
  2. Copy the analytic URL, for example,
    https://velocity.arcgis.com/.../feeds/ad17df68eac14b59a32be61f47047703/details.
  3. Provide the URL to someone you want to access the feed.
    They can use the URL to open the feed details page in Velocity.
Considerations and limitations
If a feed is shared with another Velocity user, they can visualize the feed in a web map or other mapping application. If the other user is a member of the same organization and has privileges to publish real-time analytics, they can create an analytic that processes data consumed by the feed.
Only the feed owner can edit, clone, or start a feed. Others who have access to shared feeds can only see a subset of the feed parameters.
Only users in an ArcGIS organization with Velocity enabled can open shared feeds in Velocity. Users must have a sufficient user type and role privileges to work with feeds.
Learn more about role creation and user assignment
Currently, feeds cannot be shared outside of the ArcGIS Online organization associated with the Velocity subscription.
