System requirements
Available with Workflow Manager license.
ArcGIS Workflow Manager Server has the same hardware and operating system requirements as the ArcGIS Server software component in ArcGIS Enterprise.
Software
Workflow Manager Server requires an ArcGIS Enterprise deployment.
You can install Workflow Manager Server on its own machine, separate from the hosting server machine, or on the hosting server machine. For production deployments, it is recommended that you install Workflow Manager Server on its own machine. In this scenario, ArcGIS Server must be installed but does not need to be licensed as a GIS server.
Learn more about licensing Workflow Manager
Port availability
To communicate with ArcGIS Enterprise, Workflow Manager needs access to the following ports where base deployment components are installed:
Port number |
Protocol |
Component |
13443 |
HTTPS |
Used by Workflow Manager. This port must be opened before installing the software. If there is a firewall between ArcGIS Web Adaptor and Workflow Manager, port 13443 must be open between the machine hosting ArcGIS Web Adaptor and Workflow Manager. |
7443 |
HTTPS |
Used by Portal for ArcGIS. |
6443 |
HTTPS |
Used by ArcGIS Server and any hosted or federated server machines that will be used to run tools. |
11211 |
TCP |
Used for communication between the Java Database Connectivity (JDBC) client and an Apache Ignite database inside each Workflow Manager machine. External communication over this port is not required. |
13820 13830 13840 |
TCP |
Used by highly available Workflow Manager deployments. |
View a diagram of ports used by Workflow Manager
This component is only one part of an ArcGIS Enterprise deployment.
Supported web browsers
Workflow Manager requires one of the following web browsers:
Google Chrome
Mozilla Firefox
Microsoft Edge
Use Chrome or Firefox for the best experience.
SSL certificates
Workflow Manager Server is preconfigured with a self-signed certificate that allows you to verify that the installation was successful.
You must request a certificate from a trusted certificate authority (CA) and configure Workflow Manager Server to use it. This can be a domain certificate issued by your organization or a CA-signed certificate.
Portal for ArcGIS also includes a preconfigured self-signed certificate. Because you will federate Workflow Manager Server with an ArcGIS Enterprise portal, request a certificate from a trusted CA and configure the portal to use it.
