Enable MCP for ArcGIS Enterprise
After you install MCP Services for ArcGIS Enterprise, you may need to complete additional configuration before AI applications can connect to your organization's MCP catalogs. The requirement depends on your ArcGIS Enterprise version.
ArcGIS Enterprise version Enablement requirement
12.2 and later An administrator must turn on External AI client access after MCP Services for ArcGIS Enterprise are installed.
11.1, 11.3, 11.5, and 12.1 The default catalog is available after installation. No additional step is required.
In all versions, clients must authenticate using a supported technique, and access to content, data, and services is determined by the permissions of the user or credential used for the connection. For details, see Select an authentication technique.
Enable MCP in ArcGIS Enterprise 12.2 and later
Complete the following steps:
  1. Verify that MCP Services for ArcGIS Enterprise are installed on every machine in your hosting server site.
  2. Sign in to your organization as an administrator.
  3. Turn on External AI client access by following the instructions in Configure AI settings.
    If Requirements missing appears next to the External AI client access setting, install MCP Services for ArcGIS Enterprise, and then return to this setting. For details, see Requirements missing in AI settings.
After the setting is turned on, AI applications can connect to the default catalog and to any custom catalogs shared with them. Until it is turned on, requests to any MCP catalog fail with an error stating that MCP is not enabled for the organization. For details, see MCP is not enabled for this organization.
Access MCP in earlier supported versions
For ArcGIS Enterprise 11.1, 11.3, 11.5, and 12.1, the default catalog is available after you install MCP Services for ArcGIS Enterprise. Custom catalogs are not available in these versions.
Next steps
