ContingentFieldValue
Resumen
The ContingentFieldValue object contains properties that describe the properties of the field used for a contingent value.
Debate
ContingentFieldValue objects cannot be created directly. ContingentFieldValue properties can be accessed through the values object that is returned by the arcpy.da.ListContingentValues function.
Propiedades
| Nombre | Explicación | Tipo de datos |
code (Solo lectura) |
If the contingent value uses a coded value domain, this property returns the code that is used for the contingent value. |
Long |
name (Solo lectura) |
The name of the field that participates in the field group. |
String |
range (Solo lectura) |
If the contingent value uses a range domain, this property returns the minimum and maximum values of the range for the contingent value. |
Long |
type (Solo lectura) |
Specifies the type of field value used for the contingent value.
String |
