NumPyArrayToFeatureClass
Resumen
The NumPyArrayToFeatureClass function converts a NumPy structured array to a point feature class.
Debate
If a field name from the input array is invalid for the output format, it will be validated. All invalid characters in the input field name are replaced with an underscore (_) in the output field name. Field name restrictions depend on the specific database used.
NumPyArrayToFeatureClass will not overwrite an existing feature class, even if the overwriteOutput environment is set to True.
NumPy is a fundamental package for scientific computing in Python, including support for a powerful N-dimensional array object. For more information, see NumPy in ArcGIS.
Sintaxis
NumPyArrayToFeatureClass(in_array, out_table, shape_fields, {spatial_reference})
| El parámetro | Explicación | Tipo de datos |
in_array |
A NumPy structured array. The array must include field names and NumPy dtypes. |
NumPyArray |
out_table |
The output point feature class to which the records from the NumPy array will be written. |
String |
shape_fields |
A list (or tuple) of field names used to create the feature class's geometry. Coordinates are specified in the order of x, y, z, and m; z-coordinate and m-value fields are optional. Assuming field names of x, y, z, and m in a numpy array, feature classes could be constructed as below.
String |
spatial_reference |
The spatial reference of the feature class. When this argument is specified, the feature will be projected (or transformed) from the input's spatial reference. If unspecified, the input feature classes' spatial reference will be used. Valid values for this argument are a The default value is None. |
SpatialReference |
Muestra de código
import arcpy
import numpy
outFC = "C:/data/texas.gdb/fd/pointlocations"
# Create a numpy array with an id field, and a field with a tuple
# of x,y coordinates
array = numpy.array(
(1, (471316.3835861763, 5000448.782036674)),
(2, (470402.49348005146, 5000049.216449278)),
numpy.dtype([("idfield", numpy.int32), ("XY", "<f8", 2)]),
# Define a spatial reference for the output feature class
spatial_ref = arcpy.Describe("C:/data/texas.gdb/fd").spatialReference
# Export the numpy array to a feature class using the XY field to
# represent the output point feature
arcpy.da.NumPyArrayToFeatureClass(array, outFC, ["XY"], spatial_ref)
