Parameter data types in a Python toolbox
In a Python toolbox, the parameter's datatype property is set using the Parameter class in the getParameterInfo method.
def getParameterInfo(self):
    # Define parameter definitions
    # First parameter
    param0 = arcpy.Parameter(
        displayName="Input workspace",
        name="in_workspace",
        datatype="DEWorkspace",
        parameterType="Required",
        direction="Input")
Composite data types
You may need a parameter to accept multiple data types, often referred to as a composite data type. In a Python toolbox, composite data types are defined by assigning a list of data types to the parameter's datatype property. In the following example, a parameter that accepts a raster dataset or a feature class is defined:
    # First parameter
        displayName="Input Raster Dataset",
        name="in_rasterdataset",
        datatype=["DERasterDataset", "DEFeatureClass"],
        direction="Input")
Data types
Every tool parameter has an associated data type as shown in the following table:
Data type
datatype keyword
3D Tiles Layer
GP3DTilesLayer
A 3D tiles layer references a tile set that defines an integrated mesh or 3D object type data in a hierarchical data structure.
Address Locator
DEAddressLocator
A dataset used for geocoding that stores the address attributes, associated indexes, and rules that define the process for translating nonspatial descriptions of places to spatial data.
Analysis Cell Size
analysis_cell_size
The cell size used by raster tools.
Any Value
GPType
A data type that accepts any value.
ArcMap Document
DEMapDocument
A file that contains one map, its layout, and its associated layers, tables, charts, and reports.
Areal Unit
GPArealUnit
An areal unit type and value, such as square meter or acre.
Boolean
GPBoolean
A Boolean value.
CAD Drawing Dataset
DECadDrawingDataset
A vector data source combined with feature types and symbology. The dataset cannot be used for feature class-based queries or analysis.
Calculator Expression
GPCalculatorExpression
A calculator expression.
Catalog Layer
GPCatalogLayer
A collection of references to different data types. The data types can be from different locations and are managed and visualized dynamically as layers based on location, time, and other attributes.
Catalog Root
DECatalogRoot
The top-level node in the Catalog tree.
Cell Size
GPSACellSize
The cell size used by the ArcGIS Spatial Analyst extension.
Cell Size XY
GPCellSizeXY
The size that defines the two sides of a raster cell.
Composite Layer
GPCompositeLayer
A reference to several children layers, including symbology and rendering properties.
Compression
GPSAGDBEnvCompression
The type of compression used for a raster.
Coordinate System
GPCoordinateSystem
A reference framework, such as the UTM system consisting of a set of points, lines, or surfaces, and a set of rules used to define the positions of points in two- and three-dimensional space.
Coordinate Systems Folder
DESpatialReferencesFolder
A folder on disk that stores coordinate systems.
Coverage
DECoverage
A coverage dataset, which is a proprietary data model for storing geographic features as points, arcs, and polygons with associated feature attribute tables.
Coverage Feature Class
DECoverageFeatureClasses
A coverage feature class, such as point, arc, node, route, route system, section, polygon, and region.
Data Element
DEType
A dataset visible in ArcCatalog.
Data File
GPDataFile
A data file.
Database Connections
DERemoteDatabaseFolder
The database connection folder in ArcCatalog.
Dataset
DEDatasetType
A collection of related data, usually grouped or stored together.
Date
GPDate
A date value.
dBASE Table
DEDbaseTable
Attribute data stored in dBASE format.
Decimate
GP3DADecimate
A subset of nodes of a TIN to create a generalized version of that TIN.
Diagram Layer
GPDiagramLayer
A diagram layer.
Disk Connection
DEDiskConnection
An access path to a data storage device.
Double
GPDouble
Any floating-point number stored as a double precision, 64-bit value.
Encrypted String
GPEncryptedString
An encrypted string for passwords.
Envelope
GPEnvelope
The coordinate pairs that define the minimum bounding rectangle in which the data source resides.
Evaluation Scale
GPEvaluationScale
The scale value range and increment value applied to inputs in a weighted overlay operation.
Extent
GPExtent
The coordinate pairs that define the minimum bounding rectangle (x-minimum, y-minimum and x-maximum, y-maximum) of a data source. All coordinates for the data source are within this boundary.
Extract Values
GPSAExtractValues
An extract values parameter.
Feature Class
DEFeatureClass
A collection of spatial data with the same shape type: point, multipoint, polyline, and polygon.
Feature Dataset
DEFeatureDataset
A collection of feature classes that share a common geographic area and the same spatial reference system.
Feature Layer
GPFeatureLayer
A reference to a feature class, including symbology and rendering properties.
Feature Set
GPFeatureRecordSetLayer
Interactive features that draw the features when the tool is run.
Field
Field
A column in a table that stores the values for a single attribute.
Field Info
GPFieldInfo
The details about a field in a field map.
Field Mappings
GPFieldMapping
A collection of fields in one or more input tables.
File
DEFile
A file on disk.
Folder
DEFolder
A location on disk where data is stored.
Formulated Raster
GPRasterFormulated
A raster surface whose cell values are represented by a formula or constant.
Fuzzy function
GPSAFuzzyFunction
The algorithm used in fuzzification of an input raster.
Geodataset
DEGeodatasetType
A collection of data with a common theme in a geodatabase.
GeoDataServer
DEGeoDataServer
A coarse-grained object that references a geodatabase.
Geometric Network
DEGeometricNetwork
A linear network represented by topologically connected edge and junction features. Feature connectivity is based on their geometric coincidence.
Geostatistical Layer
GPGALayer
A reference to a geostatistical data source, including symbology and rendering properties.
Geostatistical Search Neighborhood
GPGASearchNeighborhood
The searching neighborhood parameters for a geostatistical layer are defined.
Geostatistical Value Table
GPGAValueTable
A collection of data sources and fields that define a geostatistical layer.
GlobeServer
DEGlobeServer
A Globe server.
GPServer
DEGPServer
A geoprocessing server.
Graph
GPGraph
A graph.
Graph Data Table
GPGraphDataTable
A graph data table.
Group Layer
GPGroupLayer
A collection of layers that appear and act as a single layer. Group layers make it easier to organize a map, assign advanced drawing order options, and share layers for use in other maps.
Horizontal Factor
GPSAHorizontalFactor
The relationship between the horizontal cost factor and the horizontal relative moving angle.
Image Service
DEImageServer
An image service.
Index
Index
A data structure used to speed the search for records in geographic datasets and databases.
INFO Expression
GPINFOExpression
A syntax for defining and manipulating data in an INFO table.
INFO Item
GPArcInfoItem
An item in an INFO table.
INFO Table
DEArcInfoTable
A table in an INFO database.
Internet Tiled Layer
GPInternetTiledLayer
An internet tiled layer.
KML Layer
GPKMLLayer
A KML layer.
Knowledge Graph Layer
GPKnowledgeGraphLayer
A layer that visualizes entities and relationships from a knowledge graph.
LAS Dataset
DELasDataset
A LAS dataset stores reference to one or more LAS files on disk as well as to additional surface features. A LAS file is a binary file that stores airborne lidar data.
LAS Dataset Layer
GPLasDatasetLayer
A layer that references a LAS dataset on disk. This layer can apply filters on lidar files and surface constraints referenced by a LAS dataset.
Layer
GPLayer
A reference to a data source, such as a shapefile, coverage, geodatabase feature class, or raster, including symbology and rendering properties.
Layer File
DELayer
A layer file stores a layer definition, including symbology and rendering properties.
Layout
GPLayout
A layout in an ArcGIS Pro project or a layout file (.pagx).
Line
GPLine
A shape, straight or curved, defined by a connected series of unique x,y-coordinate pairs.
Linear Unit
GPLinearUnit
A linear unit type and value such as meter or feet.
Long
GPLong
An integer number value.
M Domain
GPMDomain
A range of lowest and highest possible value for m-coordinates.
Map
GPMap
An ArcGIS Pro map.
MapServer
DEMapServer
A map server.
Map Server Layer
GPMapServerLayer
A map server layer.
Mosaic Dataset
DEMosaicDataset
A collection of raster and image data that allows you to store, view, and query the data. It is a data model in the geodatabase used to manage a collection of raster datasets (images) stored as a catalog and viewed as a mosaicked image.
Mosaic Layer
GPMosaicLayer
A layer that references a mosaic dataset.
Neighborhood
GPSANeighborhood
The shape of the area around each cell used to calculate statistics.
Network Analyst Class FieldMap
NAClassFieldMap
The mapping between location properties in a Network Analyst layer (such as stops, facilities, and incidents) and a point feature class.
Network Analyst Hierarchy Settings
GPNAHierarchySettings
A hierarchy attribute that divides hierarchy values of a network dataset into three groups using two integers. The first integer sets the ending value of the first group; the second integer sets the beginning value of the third group.
Network Analyst Layer
GPNALayer
A group layer used to express and solve network routing problems. Each sublayer held in memory in a Network Analyst layer represents some aspect of the routing problem and the routing solution.
Network Data Source
GPNetworkDataSource
A network data source can be a local dataset specified using its catalog path or a layer from a map, or it can be a URL to a portal.
Network Dataset
DENetworkDataset
A collection of topologically connected network elements (edges, junctions, and turns), derived from network sources and associated with a collection of network attributes.
Network Dataset Layer
GPNetworkDatasetLayer
A reference to a network dataset, including symbology and rendering properties.
Network Travel Mode
NetworkTravelMode
A dictionary of travel mode objects.
Oriented Imagery Layer
GPOrientedImageryLayer
A collection of camera locations with image metadata.
Pairwise Weights Table
GPPairwiseWeightsTable
A table of a pairwise comparison matrix containing evaluations for each of the pairs for the input variables.
Parcel Fabric For ArcMap
DECadastralFabric
A dataset used for the storage, maintenance, and editing of a continuous surface of connected parcels or parcel network.
Parcel Fabric Layer
GPCadastralFabricLayer
A layer referencing a parcel fabric on disk. This layer works as a group layer, organizing a set of related layers under a single layer.
Point
GPPoint
A pair of x,y-coordinates.
Polygon
GPPolygon
A connected sequence of x,y-coordinate pairs in which the first and last coordinate pair are the same.
Projection File
DEPrjFile
A file storing coordinate system information for spatial data.
Pyramid
GPSAGDBEnvPyramid
Specifies whether pyramids are built.
Radius
GPSARadius
The surrounding points that are used for interpolation.
Random Number Generator
GPRandomNumberGenerator
The seed and the generator to use when creating random values.
Raster Band
DERasterBand
A layer in a raster dataset.
Raster Calculator Expression
GPRasterCalculatorExpression
A raster calculator expression.
Raster Catalog
DERasterCatalog
Heredado:
Raster catalogs are a legacy format and are not supported in ArcGIS Pro.
Raster Catalog Layer
GPRasterCatalogLayer
Heredado:
Raster catalog layers are a legacy format and are not supported in ArcGIS Pro.
Raster Data Layer
GPRasterDataLayer
A raster data layer.
Raster Dataset
DERasterDataset
A single dataset built from one or more rasters.
Raster Layer
GPRasterLayer
A reference to a raster, including symbology and rendering properties.
Raster Statistics
GPSAGDBEnvStatistics
Specifies whether raster statistics will be built.
Raster Type
GPRasterBuilder
Raster data is added to a mosaic dataset by specifying a raster type. The raster type identifies metadata, such as georeferencing, acquisition date, and sensor type, with a raster format.
Record Set
GPRecordSet
An interactive table. Provide the table values when the tool is run.
Relationship Class
DERelationshipClass
The details about the relationship between objects in the geodatabase.
Remap
GPSARemap
A table that defines how raster cell values are reclassified.
Route Measure Event Properties
GPRouteMeasureEventProperties
The fields on a table that describe events measured by a linear reference route system.
Scene Service Layer
GPSceneServiceLayer
A scene service layer.
Schematic Dataset
DESchematicDataset
A collection of schematic diagram templates and schematic feature classes that share the same application domain, for example, water or electrical.
Schematic Diagram
DESchematicDiagram
A schematic diagram.
Schematic Diagram Class
DESchematicDiagramClass
A schematic diagram class.
Schematic Folder
DESchematicFolder
A schematic folder.
Schematic Layer
GPSchematicLayer
A composite layer composed of feature layers based on the schematic feature classes associated with the template on which the schematic diagram is based.
SemiVariogram
GPSASemiVariogram
The distance and direction representing two locations used to quantify autocorrelation.
ServerConnection
DEServerConnection
A server connection.
Shapefile
DEShapeFile
Spatial data in shapefile format.
Spatial Reference
GPSpatialReference
The coordinate system used to store a spatial dataset, including the spatial domain.
SQL Expression
GPSQLExpression
A syntax for defining and manipulating data from a relational database.
String
GPString
A text value.
String Hidden
GPStringHidden
A string that is masked by asterisk characters.
Nota:
The text is not encrypted when used in scripting.
Table
DETable
Tabular data.
Table View
GPTableView
A representation of tabular data for viewing and editing purposes stored in memory or on disk.
Terrain Layer
GPTerrainLayer
A reference to a terrain, including symbology and rendering properties. It’s used to draw a terrain.
Text File
DETextfile
A text file.
Tile Size
GPSAGDBEnvTileSize
The width and height of data stored in block.
Time configuration
GPSATimeConfiguration
The time periods used for calculating solar radiation at specific locations.
Time Unit
GPTimeUnit
A time unit type and value such as minutes or hours.
TIN
DETin
A vector data structure that partitions geographic space into contiguous, nonoverlapping triangles. The vertices of each triangle are sample data points with x-, y-, and z-values.
Tin Layer
GPTinLayer
A reference to a TIN, including topological relationships, symbology, and rendering properties.
Tool
DETool
A geoprocessing tool.
Toolbox
DEToolbox
A geoprocessing toolbox.
Topo Features
GPSATopoFeatures
Features that are input to the interpolation.
Topology
DETopology
A topology that defines and enforces data integrity rules for spatial data.
Topology Layer
GPTopologyLayer
A reference to a topology, including symbology and rendering properties.
Trajectory Layer
GPTrajectoryLayer
A layer that references a trajectory dataset.
Transformation Function
GPSATransformationFunction
A Spatial Analyst transformation function.
Utility Network
DEUtilityNetwork
A utility network.
Utility Network Layer
GPUtilityNetworkLayer
A utility network layer.
Value Table
GPValueTable
A collection of columns of values.
Variant
GPVariant
A data value that can contain any basic type: Boolean, date, double, long, and string.
Vector Tile Layer
GPVectorLayer
A vector tile layer.
Vertical Factor
GPSAVerticalFactor
The relationship between the vertical cost factor and the vertical, relative moving angle.
VPF Coverage
DEVPFCoverage
Spatial data stored in Vector Product Format.
VPF Table
DEVPFTable
Attribute data stored in Vector Product Format.
WCS Coverage
DEWCSCoverage
Web Coverage Service (WCS) is an open specification for sharing raster datasets on the web.
Weighted Overlay Table
GPSAWeightedOverlayTable
A table with data to combine multiple rasters by applying a common measurement scale of values to each raster, weighing each according to its importance.
Weighted Sum
GPSAWeightedSum
Data for overlaying several rasters, each multiplied by their given weight and summed.
WMS Map
DEWMSMap
A Web Map Service (WMS) specification map.
Workspace
DEWorkspace
A container such as a geodatabase or folder.
XY Domain
GPXYDomain
A range of lowest and highest possible values for x,y-coordinates.
Z Domain
GPZDomain
A range of lowest and highest possible values for z-coordinates.
