Using fields and indexes
When described, feature classes and tables have a fields property that returns a list of Field objects and an indexes property that returns a list of Index objects. Each field or index object has a number of properties that can be used to explore the object. Alternatively, the ListFields and ListIndexes functions can be used to create the same lists.
ListFields(dataset, wild_card, field_type)
Returns a list of fields found in the input value
ListIndexes(dataset, wild_card)
Returns a list of attribute indexes found in the input value
List functions
The following example shows how to create a field list and loop through the contents to find a specific field.
import arcpy
fc = 'D:/St_Johns/data.gdb/roads'
# Get a list of field objects
fields = arcpy.ListFields(fc, 'Flag')
for field in fields:
    # Check the field name, perform a calculation when finding the field 'Flag'
    if field.name == 'Flag':
        # Set the value for the field and exit loop
        arcpy.management.CalculateField(fc, 'Flag', '1')
        break
The properties of the field and index objects are listed below:
Property
Explanation
name
The name of the field.
aliasName
The alias name of the field.
domain
The name of the associated domain.
editable
True, if the field is editable.
isNullable
True, if the field is nullable.
required
True, if the field is required.
length
The field's length.
type
SmallInteger, Integer, Single, Double, String, Date, OID, Geometry, BLOB.
scale
The field's scale.
precision
The field's precision.
Field properties
Property
Explanation
name
The name of the index.
isAscending
True, if the index sorts in ascending order.
isUnique
True, if the index is unique.
fields
A list of Field objects. This is the same as using Describe fields property.
Index properties
Sugerencia:
ListFields and ListIndexes can be used to limit the results based on name and type.
