WindChill
Resumen
Identifies dangerous winter conditions that, depending on exposure times to the elements, can result in frostbite or hypothermia.
Debate
The formula the function uses to compute wind chill is as follows:
\({Wind\ Chill} = 35.74 + (0.6215 * T) - (35.75\ * WS^{0.16}) + (0.4275\ *\ T\ * WS^{0.16})\)
T = Air Temperature in degrees Fahrenheit
WS = Wind speed in miles per hour
For more information about how this function works, see the Wind Chill raster function.
The referenced raster dataset for the raster object is temporary. To make it permanent, you can call the raster object's save method.
Sintaxis
WindChill(temperature_raster, wind_speed_raster, {temperature_units}, {wind_speed_units}, {wind_chill_units})
| El parámetro | Explicación | Tipo de datos |
temperature_raster |
A single-band raster where pixel values represent ambient air temperature. |
Raster |
wind_speed_raster |
A single-band raster where pixel values represent wind speed. |
Raster |
temperature_units |
The unit of measurement associated with the input temperature raster. Available input units are Celsius, Fahrenheit, and Kelvin. The default value is Fahrenheit. |
String |
wind_speed_units |
Defines the unit of measurement for the wind-speed raster:
The default value is mph. |
String |
wind_chill_units |
The unit of measurement associated with the output raster. Available output units are Celsius, Fahrenheit, and Kelvin. The default value is Fahrenheit. |
String |
Valor de retorno
| Tipo de datos | Explicación |
Raster |
The output raster. |
Muestra de código
Calculates wind chill based on the temperature and wind speed from the input raster.
from arcpy.ia import *
out_windchill_raster = WindChill("temperature.tif", "windspeed.tif", "",
"km/h", "Celsius")
out_windchill_raster.save("C:/arcpyExamples/outputs/wind_chill_C.tif")
# Import system modules
import arcpy
# Set the analysis environments
arcpy.env.workspace = "C:/arcpyExamples/data"
# Set the local variables
in_temperature_raster = "temperature.tif"
in_wind_speed_raster = "windspeed.tif"
# Run WindChill function
out_windchill_raster = WindChill(in_temperature_raster, in_wind_speed_raster,
"", "knots", "Kelvin")
# Save the output
out_windchill_raster.save("C:/arcpyExamples/outputs/wind_chill_K.tif")
