EPSFormat
Resumen
The EPSFormat object represents a collection of Encapsulated PostScript (EPS) file properties that can be configured and used with the export method on the Layout, MapFrame, and MapView objects to create an output EPS file.
Debate
EPS format files use the PostScript page description language to describe vector and raster objects. PostScript is the publishing industry standard for high-end graphics files, cartography, and printing. EPS files can be edited in many drawing applications or placed as a graphic in most page layout applications. EPS format supports font embedding and can define colors in CMYK or RGB values.
The createExportFormat method can be used to create a EPSFormat object if the format parameter is set to EPS. The returned EMFFormat object contains all the properties associated with a generating a EPS file. These properties can be modified accordingly to produce different output results.
Propiedades
| Nombre | Explicación | Tipo de datos |
clipToElements (Lectura y escritura) |
If set to |
Boolean |
convertMarkers (Lectura y escritura) |
Controls whether marker symbols based on font characters are exported as font characters or as polygons. Set this option to |
Boolean |
embedFonts (Lectura y escritura) |
Include embeddable fonts in the exported file to maintain font consistency across different platforms. Fonts that do not support embedding are not included, regardless of this setting. The default value is Nota:To correctly edit text as graphics, Illustrator requires fonts to be installed and accessible. Check the sharing permissions before embedding and sharing fonts. For high-range characters or ligatures, font embedding should be used to ensure proper addressing of these high-range characters. In the case where a font with high-range characters or ligatures cannot be embedded, check the Draw glyphs as geometry property on the text symbol. |
Boolean |
filePath (Lectura y escritura) |
A string that represents the system path and file name, including the extension, for the exported file. |
String |
height (Lectura y escritura) |
The height, in pixels, of the map area to be exported. This property only applies when exporting a |
Double |
imageCompression (Lectura y escritura) |
The compression scheme used to compress image or raster data in the output file. The default value is
String |
imageQuality (Lectura y escritura) |
The amount of image resampling. The property determines the effective resolution of raster content on output. For instance, if
String |
outputAsImage (Lectura y escritura) |
Export vector content as an image. For maps or layouts containing vector layers with a high density of vertices, this can drastically reduce the output file size. The default value is Nota:Options specific to vector data, such as |
Boolean |
resolution (Lectura y escritura) |
The effective dpi of the output vector data. The default value is 96. Nota:When exporting a |
Integer |
showSelectionSymbology (Lectura y escritura) |
Show selected features in the map or map frame as selected in the output file. Setting this value to |
Boolean |
width (Lectura y escritura) |
The width, in pixels, of the map area to be exported. This property only applies when exporting a |
Double |
Métodos
setImageCompression(eps_image_compression)
A string constant that represents the compression scheme used to compress image or raster data in the output file.
eps_image_compression |
Below is a list of valid strings.
String |
setImageQuality(image_quality)
A string constant that sets the amount of image resampling.
The value determines the effective resolution of raster content on output. For instance, if the output image quality ratio is set to 1:2, an image_quality value of BETTER, and the output resolution is set to 300 dpi, the raster content is output at approximately 150 dpi. In many cases, the raster data can be included at a lower dpi than the vector data without visibly affecting quality, reducing the output file size.
image_quality |
String |
Muestra de código
The following script exports a layout to EPS format using default property values.
p = arcpy.mp.ArcGISProject('current')
lyt = p.listLayouts()[0]
eps = arcpy.mp.CreateExportFormat('EPS', r'C:\Temp\output.eps')
lyt.export(eps)
