PNGFormat
Resumen
The PNGFormat object represents a collection of Portable Network Graphics (PNG) file properties that can be configured and used with the export method on the Layout, MapFrame, MapView, MapSeries and BookmarkMapSeries objects to create an output PNG file.
Debate
PNG is a versatile raster format that can be displayed in web browsers and inserted into other documents. It supports high-bit-depth color and uses a lossless compression. For maps, PNG is often the best raster format, since the lossless compression keeps text and line work legible by preventing the compression artifacts that can occur in JPEG format. PNG files can also define a transparent color; part of the image can be displayed as transparent in a web browser, allowing backgrounds, images, or colors to show through. PNGs can be generated with an accompanying world file for use as georeferenced raster data.
The createExportFormat method can be used to create a PNGFormat object if the format parameter is set to PNG. The returned PNGFormat object contains all the properties associated with a generating a PNG file. These properties can be modified accordingly to produce different output results.
Propiedades
| Nombre | Explicación | Tipo de datos |
clipToElements (Lectura y escritura) |
If set to |
Boolean |
colorMode (Lectura y escritura) |
A string constant that represents the number of bits to describe color in a pixel. The default value is
String |
filePath (Lectura y escritura) |
A string that represents the system path and file name, including the extension, for the exported file. |
String |
geoReferenceMapFrame (Lectura y escritura) |
The MapFrame used to control the coordinate system when the |
MapFrame |
height (Lectura y escritura) |
The height, in pixels, of the map area to be exported. This property only applies when exporting a |
Double |
resolution (Lectura y escritura) |
The effective dpi of the output vector data. The default value is 96. Nota:When exporting a |
Integer |
showSelectionSymbology (Lectura y escritura) |
Show selected features in the map or map frame as selected in the output file. Setting this value to |
Boolean |
threshold (Lectura y escritura) |
Image intensities set above this value will appear white in the output file and all other values will appear black. This property is applied only when the |
Boolean |
transparentBackground (Lectura y escritura) |
If set to Nota:Transparent backgrounds are only supported when |
Boolean |
width (Lectura y escritura) |
The width, in pixels, of the map area to be exported. This property only applies when exporting a |
Double |
worldFile (Lectura y escritura) |
If set to |
Boolean |
Métodos
setColorMode(color_mode)
color_mode |
Below is a list of valid strings.
String |
Muestra de código
The following script exports a layout to PNG format using default property values.
p = arcpy.mp.ArcGISProject('current')
lyt = p.listLayouts()[0]
png = arcpy.mp.CreateExportFormat('PNG', r'C:\Temp\Output.png')
lyt.export(png)
