RasterStretchColorizer
Resumen
Represents a raster stretch colorizer.
Debate
The raster stretch colorizer stretches values along a color ramp. The properties behave in a similar manner to the options exposed in the application. For example, changing the StretchType will control a subset of additional parameters that can be modified.
Propiedades
Nombre Explicación Tipo de datos
band
(Lectura y escritura)
An integer that represents a zero-based index matching the order of the bands the way they appear in the Symbology pane. The topmost band is index 0 and the bottommost is n-1.
Integer
colorRamp
Provides access to the ColorRamp object.
ColorRamp
gamma
A double that represents the gamma value.
Double
invertColorRamp
A Boolean that reverses the color ramp's appearance.
Boolean
maxLabel
A string that represents the raster stretch maximum label that appears in the Contents pane or legend.
String
maxPercent
A double that represents the percentage of highest values to cut from the source data. This parameter is only applied if the StretchType is set to MinimumMaximum.
Double
minLabel
A string that represents the raster stretch minimum label that appears in the Contents pane or legend.
String
minPercent
A double that represents the percentage of lowest values to cut from the source data. This parameter is only applied if the StretchType is set to MinimumMaximum.
Double
standardDeviation
A double that represents the standard deviation value. This parameter is only applied if the StretchType is set to StandardDeviation.
Double
stretchType
A string that represents a valid stretching algorithm. The valid values are as follows:
  • Custom—Display values with custom histogram.
  • Esri—Highlight the contrast of moderate values while minimizing the impact of extreme high and low values.
  • HistogramEqualize—Display values with histogram equalize.
  • HistogramSpecification—Display values with histogram specification.
  • MinimumMaximum—Display values between the actual minimum and maximum values.
  • None—Display values between potential minimum and maximum.
  • PercentClip—Cut off percentages of highest and lowest values.
  • StandardDeviation—Display values between a specified number of standard deviations.
String
type
(Solo lectura)
Returns a string that represents the colorizer type.
String
Muestra de código
RasterStretchColorizer example
The following script first tests whether the layer's symbology supports a colorizer property, then confirms whether the renderer is a RasterStretchColorizer. Next,. it changes the stretchType to PercentClip and sets the appropriate min/max percents. Finally, it changes ColorRamp to a color ramp named Bathymetry #2.
p = arcpy.mp.ArcGISProject('current')
m = p.listMaps('RasterStretch')[0]
for l in m.listLayers():
  if l.isRasterLayer:
    sym = l.symbology
    if hasattr(sym, 'colorizer'):
      if sym.colorizer.type == 'RasterStretchColorizer':
        #Set StretchType = PercentClip
        if l.name == "Photo_SE":
          sym.colorizer.stretchType = "PercentClip"
          sym.colorizer.minPercent = 1.0
          sym.colorizer.maxPercent = 1.0
          cr = p.listColorRamps('Bathymetry #2')[0]
          sym.colorizer.colorRamp = cr
          sym.colorizer.invertColorRamp = True
          sym.colorizer.gamma = 2
          sym.colorizer.minLabel = "Min: " + sym.colorizer.minLabel
          sym.colorizer.maxLabel = "Max: " + sym.colorizer.maxLabel
          l.symbology = sym
