ClosestFacilityOutputDataType
Resumen
Enumeration of output types for the ClosestFacility solver.
Propiedades
| Nombre | Explicación | Tipo de datos |
Incidents (Solo lectura) |
Specifies the output incidents for the Closest Facility analysis. |
Object |
Facilities (Solo lectura) |
Specifies the output facilities for the Closest Facility analysis. |
Object |
Routes (Solo lectura) |
Specifies the output routes between facilities and incidents calculated in the Closest Facility analysis. |
Object |
ClosestFacilities (Solo lectura) |
Specifies the output closest facilities for the Closest Facility analysis. This subset of the output facilities includes only those facilities that were closest to at least one of the incidents. |
Object |
Directions (Solo lectura) |
The output turn-by-turn directions for the routes calculated in the analysis. Heredado:This output type has been superseded by |
Object |
DirectionPoints (Solo lectura) |
This is the output turn-by-turn directions for the routes calculated in the analysis, represented as point locations along the routes where specific direction events or maneuvers occur. |
Object |
DirectionLines (Solo lectura) |
This is the output route lines calculated in the analysis sliced to represent each route segment between |
Object |
