DirectionsCustomizer
Resumen
A base class for a directions customizer.
Debate
This class is used as the base class when creating a directions customizer class (class MyCustDirs(arcpy.nax.DirectionsCustomizer)).
Métodos
attach(network_query)
Verifies that the direction customizer can be attached to the network.
It is invoked when the direction customizer is attached to the network dataset. It may be invoked multiple times depending on the number of threads accessing the network.
Nombre Explicación Tipo de datos
network_query
The network query instance for the current network dataset.
NetworkQuery
Valor de retorno
Tipo de datos Explicación
Boolean
True, if the direction customizer can be attached to the network dataset
customize(directions_query)
Customizes the final directions output.
It is invoked by the directions engine once per route.
directions_query
The directions query instance for the current route.
DirectionsQuery
