LastMileDeliveryInputDataType
Resumen
Enumeration of input types for the LastMileDelivery solver.
Propiedades
Nombre Explicación Tipo de datos
Orders
(Solo lectura)
The orders that will be used as input for the Last Mile Delivery analysis. These are the final customer locations where the routes deliver the packages or initial customer location where they are picking up packages for shipment.
Object
Depots
(Solo lectura)
The depots that will be used as input for the Last Mile Delivery analysis. A depot is a location that a vehicle departs from at the beginning of its workday and returns to at the end of the workday.
Object
Routes
(Solo lectura)
The routes that will be used as input for the Last Mile Delivery analysis. A route defines vehicle and driver characteristics.
Object
OrderSpecialties
(Solo lectura)
The specialties that are required by orders. A route can service an order only if it supports all the specialties required for that order. For example, an order may require a technician with a certain skill set or a vehicle with certain capabilities.
Object
RouteSpecialties
(Solo lectura)
The specialties that are supported by routes. A route can service an order only if the route supports all the specialties required for that order. For example, an order may require a technician with a certain skill set or a vehicle with certain capabilities.
Object
Zones
(Solo lectura)
The route zones that will be used as input for the analysis. A zone is a polygon that delineates work territories for given routes and is used to constrain routes to servicing only those orders that are within or near the specified area.
Object
PointBarriers
(Solo lectura)
Point barriers that temporarily restrict traversal across or add impedance to points on the network.
Object
LineBarriers
(Solo lectura)
Line barriers that temporarily restrict traversal across a line.
Object
PolygonBarriers
(Solo lectura)
Polygon barriers that temporarily restrict traversal or scale impedance on the parts of the network they cover.
Object
