ColorspaceConversion
Resumen
Converts the color model of a three-band unsigned 8-bit image from the hue, saturation, and value (HSV) to red, green, and blue (RGB) or vice versa.
Debate
For more information about how this function works, see the Color Model Conversion raster function.
The referenced raster dataset for the raster object is temporary. To make it permanent, you can call the raster object's save method.
Sintaxis
ColorspaceConversion(raster, {conversion_type})
| El parámetro | Explicación | Tipo de datos |
raster |
An unsigned 8-bit pixel type input raster. |
Raster |
conversion_type |
The color conversion type to perform.
The default value is rgb_to_hsv. |
String |
Valor de retorno
| Tipo de datos | Explicación |
Raster |
The output raster. |
Muestra de código
This example applies the Colorspace Conversion function to the input raster.
from arcpy.sa import *
out_hsv_3bands = ColorspaceConversion("slope_rgb_3bands.tif", "rgb_to_hsv")
out_hsv_3bands.save("C:/arcpyExamples/outputs/slope_hsv_3bands.tif")
# Import system modules
import arcpy
# Set the analysis environments
arcpy.env.workspace = "C:/arcpyExamples/data"
# Set the local variables
# the pixeltype of the input raster must be unsigned 8-bit, otherwise,
# the function would fail
in_raster = "slope_rgb_3bands.tif"
# Run ColorspaceConversion function
slope_hsv_3bands = ColorspaceConversion(in_raster, "rgb_to_hsv")
# Save the output
slope_hsv_3bands.save("C:/arcpyExamples/outputs/slope_hsv_3bands.tif")
