Parameter data types in a Python toolbox
In a Python toolbox, the parameter's datatype property is set using the Parameter class in the getParameterInfo method.
def getParameterInfo(self):
# Define parameter definitions
# First parameter
param0 = arcpy.Parameter(
displayName="Input workspace",
name="in_workspace",
datatype="DEWorkspace",
parameterType="Required",
direction="Input")
Composite data types
You may need a parameter to accept multiple data types, often referred to as a composite data type. In a Python toolbox, composite data types are defined by assigning a list of data types to the parameter's datatype property. In the following example, a parameter that accepts a raster dataset or a feature class is defined:
# First parameter
displayName="Input Raster Dataset",
name="in_rasterdataset",
datatype=["DERasterDataset", "DEFeatureClass"],
direction="Input")
Data types
Every tool parameter has an associated data type as shown in the following table:
Data type |
Description |
3D Tiles Layer |
A 3D tiles layer references a tile set that defines an integrated mesh or 3D object type data in a hierarchical data structure. |
Address Locator |
A dataset used for geocoding that stores the address attributes, associated indexes, and rules that define the process for translating nonspatial descriptions of places to spatial data. |
Analysis Cell Size |
The cell size used by raster tools. |
Any Value |
A data type that accepts any value. |
ArcMap Document |
A file that contains one map, its layout, and its associated layers, tables, charts, and reports. |
Areal Unit |
An areal unit type and value, such as square meter or acre. |
Boolean |
A Boolean value. |
CAD Drawing Dataset |
A vector data source combined with feature types and symbology. The dataset cannot be used for feature class-based queries or analysis. |
Calculator Expression |
A calculator expression. |
Catalog Layer |
A collection of references to different data types. The data types can be from different locations and are managed and visualized dynamically as layers based on location, time, and other attributes. |
Catalog Root |
The top-level node in the Catalog tree. |
Cell Size |
The cell size used by the ArcGIS Spatial Analyst extension. |
Cell Size XY |
The size that defines the two sides of a raster cell. |
Composite Layer |
A reference to several children layers, including symbology and rendering properties. |
Compression |
The type of compression used for a raster. |
Coordinate System |
A reference framework, such as the UTM system consisting of a set of points, lines, or surfaces, and a set of rules used to define the positions of points in two- and three-dimensional space. |
Coordinate Systems Folder |
A folder on disk that stores coordinate systems. |
Coverage |
A coverage dataset, which is a proprietary data model for storing geographic features as points, arcs, and polygons with associated feature attribute tables. |
Coverage Feature Class |
A coverage feature class, such as point, arc, node, route, route system, section, polygon, and region. |
Data Element |
A dataset visible in ArcCatalog. |
Data File |
A data file. |
Database Connections |
The database connection folder in ArcCatalog. |
Dataset |
A collection of related data, usually grouped or stored together. |
Date |
A date value. |
dBASE Table |
Attribute data stored in dBASE format. |
Decimate |
A subset of nodes of a TIN to create a generalized version of that TIN. |
Diagram Layer |
A diagram layer. |
Disk Connection |
An access path to a data storage device. |
Double |
Any floating-point number stored as a double precision, 64-bit value. |
Encrypted String |
An encrypted string for passwords. |
Envelope |
The coordinate pairs that define the minimum bounding rectangle in which the data source resides. |
Evaluation Scale |
The scale value range and increment value applied to inputs in a weighted overlay operation. |
Extent |
The coordinate pairs that define the minimum bounding rectangle (x-minimum, y-minimum and x-maximum, y-maximum) of a data source. All coordinates for the data source are within this boundary. |
Extract Values |
An extract values parameter. |
Feature Class |
A collection of spatial data with the same shape type: point, multipoint, polyline, and polygon. |
Feature Dataset |
A collection of feature classes that share a common geographic area and the same spatial reference system. |
Feature Layer |
A reference to a feature class, including symbology and rendering properties. |
Feature Set |
Interactive features that draw the features when the tool is run. |
Field |
A column in a table that stores the values for a single attribute. |
Field Info |
The details about a field in a field map. |
Field Mappings |
A collection of fields in one or more input tables. |
File |
A file on disk. |
Folder |
A location on disk where data is stored. |
Formulated Raster |
A raster surface whose cell values are represented by a formula or constant. |
Fuzzy function |
The algorithm used in fuzzification of an input raster. |
Geodataset |
A collection of data with a common theme in a geodatabase. |
GeoDataServer |
A coarse-grained object that references a geodatabase. |
Geometric Network |
A linear network represented by topologically connected edge and junction features. Feature connectivity is based on their geometric coincidence. |
Geostatistical Layer |
A reference to a geostatistical data source, including symbology and rendering properties. |
Geostatistical Search Neighborhood |
The searching neighborhood parameters for a geostatistical layer are defined. |
Geostatistical Value Table |
A collection of data sources and fields that define a geostatistical layer. |
GlobeServer |
A Globe server. |
GPServer |
A geoprocessing server. |
Graph |
A graph. |
Graph Data Table |
A graph data table. |
Group Layer |
A collection of layers that appear and act as a single layer. Group layers make it easier to organize a map, assign advanced drawing order options, and share layers for use in other maps. |
Horizontal Factor |
The relationship between the horizontal cost factor and the horizontal relative moving angle. |
Image Service |
An image service. |
Index |
A data structure used to speed the search for records in geographic datasets and databases. |
INFO Expression |
A syntax for defining and manipulating data in an INFO table. |
INFO Item |
An item in an INFO table. |
INFO Table |
A table in an INFO database. |
Internet Tiled Layer |
An internet tiled layer. |
KML Layer |
A KML layer. |
Knowledge Graph Layer |
A layer that visualizes entities and relationships from a knowledge graph. |
LAS Dataset |
A LAS dataset stores reference to one or more LAS files on disk as well as to additional surface features. A LAS file is a binary file that stores airborne lidar data. |
LAS Dataset Layer |
A layer that references a LAS dataset on disk. This layer can apply filters on lidar files and surface constraints referenced by a LAS dataset. |
Layer |
A reference to a data source, such as a shapefile, coverage, geodatabase feature class, or raster, including symbology and rendering properties. |
Layer File |
A layer file stores a layer definition, including symbology and rendering properties. |
Layout |
A layout in an ArcGIS Pro project or a layout file ( |
Line |
A shape, straight or curved, defined by a connected series of unique x,y-coordinate pairs. |
Linear Unit |
A linear unit type and value such as meter or feet. |
Long |
An integer number value. |
M Domain |
A range of lowest and highest possible value for m-coordinates. |
Map |
An ArcGIS Pro map. |
MapServer |
A map server. |
Map Server Layer |
A map server layer. |
Mosaic Dataset |
A collection of raster and image data that allows you to store, view, and query the data. It is a data model in the geodatabase used to manage a collection of raster datasets (images) stored as a catalog and viewed as a mosaicked image. |
Mosaic Layer |
A layer that references a mosaic dataset. |
Neighborhood |
The shape of the area around each cell used to calculate statistics. |
Network Analyst Class FieldMap |
The mapping between location properties in a Network Analyst layer (such as stops, facilities, and incidents) and a point feature class. |
Network Analyst Hierarchy Settings |
A hierarchy attribute that divides hierarchy values of a network dataset into three groups using two integers. The first integer sets the ending value of the first group; the second integer sets the beginning value of the third group. |
Network Analyst Layer |
A group layer used to express and solve network routing problems. Each sublayer held in memory in a Network Analyst layer represents some aspect of the routing problem and the routing solution. |
Network Data Source |
A network data source can be a local dataset specified using its catalog path or a layer from a map, or it can be a URL to a portal. |
Network Dataset |
A collection of topologically connected network elements (edges, junctions, and turns), derived from network sources and associated with a collection of network attributes. |
Network Dataset Layer |
A reference to a network dataset, including symbology and rendering properties. |
Network Travel Mode |
A dictionary of travel mode objects. |
Oriented Imagery Layer |
A collection of camera locations with image metadata. |
Pairwise Weights Table |
A table of a pairwise comparison matrix containing evaluations for each of the pairs for the input variables. |
Parcel Fabric For ArcMap |
A dataset used for the storage, maintenance, and editing of a continuous surface of connected parcels or parcel network. |
Parcel Fabric Layer |
A layer referencing a parcel fabric on disk. This layer works as a group layer, organizing a set of related layers under a single layer. |
Point |
A pair of x,y-coordinates. |
Polygon |
A connected sequence of x,y-coordinate pairs in which the first and last coordinate pair are the same. |
Projection File |
A file storing coordinate system information for spatial data. |
Pyramid |
Specifies whether pyramids are built. |
Radius |
The surrounding points that are used for interpolation. |
Random Number Generator |
The seed and the generator to use when creating random values. |
Raster Band |
A layer in a raster dataset. |
Raster Calculator Expression |
A raster calculator expression. |
Raster Catalog |
Héritage :Raster catalogs are a legacy format and are not supported in ArcGIS Pro. |
Raster Catalog Layer |
Héritage :Raster catalog layers are a legacy format and are not supported in ArcGIS Pro. |
Raster Data Layer |
A raster data layer. |
Raster Dataset |
A single dataset built from one or more rasters. |
Raster Layer |
A reference to a raster, including symbology and rendering properties. |
Raster Statistics |
Specifies whether raster statistics will be built. |
Raster Type |
Raster data is added to a mosaic dataset by specifying a raster type. The raster type identifies metadata, such as georeferencing, acquisition date, and sensor type, with a raster format. |
Record Set |
An interactive table. Provide the table values when the tool is run. |
Relationship Class |
The details about the relationship between objects in the geodatabase. |
Remap |
A table that defines how raster cell values are reclassified. |
Route Measure Event Properties |
The fields on a table that describe events measured by a linear reference route system. |
Scene Service Layer |
A scene service layer. |
Schematic Dataset |
A collection of schematic diagram templates and schematic feature classes that share the same application domain, for example, water or electrical. |
Schematic Diagram |
A schematic diagram. |
Schematic Diagram Class |
A schematic diagram class. |
Schematic Folder |
A schematic folder. |
Schematic Layer |
A composite layer composed of feature layers based on the schematic feature classes associated with the template on which the schematic diagram is based. |
SemiVariogram |
The distance and direction representing two locations used to quantify autocorrelation. |
ServerConnection |
A server connection. |
Shapefile |
Spatial data in shapefile format. |
Spatial Reference |
The coordinate system used to store a spatial dataset, including the spatial domain. |
SQL Expression |
A syntax for defining and manipulating data from a relational database. |
String |
A text value. |
String Hidden |
A string that is masked by asterisk characters. Remarque :The text is not encrypted when used in scripting. |
Table |
Tabular data. |
Table View |
A representation of tabular data for viewing and editing purposes stored in memory or on disk. |
Terrain Layer |
A reference to a terrain, including symbology and rendering properties. It’s used to draw a terrain. |
Text File |
A text file. |
Tile Size |
The width and height of data stored in block. |
Time configuration |
The time periods used for calculating solar radiation at specific locations. |
Time Unit |
A time unit type and value such as minutes or hours. |
TIN |
A vector data structure that partitions geographic space into contiguous, nonoverlapping triangles. The vertices of each triangle are sample data points with x-, y-, and z-values. |
Tin Layer |
A reference to a TIN, including topological relationships, symbology, and rendering properties. |
Tool |
A geoprocessing tool. |
Toolbox |
A geoprocessing toolbox. |
Topo Features |
Features that are input to the interpolation. |
Topology |
A topology that defines and enforces data integrity rules for spatial data. |
Topology Layer |
A reference to a topology, including symbology and rendering properties. |
Trajectory Layer |
A layer that references a trajectory dataset. |
Transformation Function |
A Spatial Analyst transformation function. |
Utility Network |
A utility network. |
Utility Network Layer |
A utility network layer. |
A collection of columns of values. |
Variant |
A data value that can contain any basic type: Boolean, date, double, long, and string. |
Vector Tile Layer |
A vector tile layer. |
Vertical Factor |
The relationship between the vertical cost factor and the vertical, relative moving angle. |
VPF Coverage |
Spatial data stored in Vector Product Format. |
VPF Table |
Attribute data stored in Vector Product Format. |
WCS Coverage |
Web Coverage Service (WCS) is an open specification for sharing raster datasets on the web. |
Weighted Overlay Table |
A table with data to combine multiple rasters by applying a common measurement scale of values to each raster, weighing each according to its importance. |
Weighted Sum |
Data for overlaying several rasters, each multiplied by their given weight and summed. |
WMS Map |
A Web Map Service (WMS) specification map. |
Workspace |
A container such as a geodatabase or folder. |
XY Domain |
A range of lowest and highest possible values for x,y-coordinates. |
Z Domain |
A range of lowest and highest possible values for z-coordinates. |
