LinearUnmixing
Résumé
Performs subpixel classification and calculates the fractional abundance of land-cover types for individual pixels.
Discussion
For more information about how this function works, see the Linear Spectral Unmixing raster function.
The referenced raster dataset for the raster object is temporary. To make it permanent, you can call the raster object's save method.
Syntaxe
LinearUnmixing(in_raster, in_spectral_profile_file, {value_option})
| Le paramètre | Explication | Type de données |
in_raster |
The input raster. |
Raster |
in_spectral_profile_file |
The path to the spectral profile for the various land cover classes. This can be provided as a polygon feature class, a classifier definition file ( |
String |
value_option |
Specifies how the output pixel values will be defined.
Both options can be specified by delimiting with a semicolon: |
String |
Valeur de retour
| Type de données | Explication |
Raster |
The output raster. |
Exemple de code
This example resolves the fractional class values for each pixel in the multispectral raster.
from arcpy.ia import *
out_linearunmixing_raster = LinearUnmixing(
"Landsat8.tif","C:/arcpyExamples/data/training_feature.ecd")
out_linearunmixing_raster.save(
"C:/arcpyexamples/outputs/linearunmix_output.tif")
# Import system modules
import arcpy
# Set the local variables
in_raster = "C:/data/Landsat_8.tif"
in_spectral_profile = "C:/data/training_features.ecd"
value_options = "SUM_TO_ONE;NON_NEGATIVE"
# Apply LinearSpectralUnmixing function
unmixing_outputs = LinearUnmixing(in_raster, in_spectral_profile, value_options)
# Save the output
unmixing_outputs.save("C:/arcpyExamples/outputs/unmixing_results.tif")
