GraduatedColorsRenderer
Résumé
The GraduatedColorsRenderer class represents the graduated color renderer definition that shows qualitative differences in feature values using a range of color.
Discussion
The properties behave in a similar manner to the options exposed in the application. For example, changing the number of classes will automatically adjust the break values and their labels. If you change upperBound of a ClassBreak, the classificationMethod automatically changes to ManualInterval. You also need to manually update the labels and/or descriptions accordingly.
Propriétés
Nom Explication Type de données
breakCount
(Lecture et écriture)
An integer that represents the number of classes to be used with the current classification method.
Integer
classBreaks
A list of ClassBreak objects that provides access to individual properties such as label and description as well as individual symbol objects.
List
classificationField
A string that represents a valid field name used for the layer's classification method.
String
A string that represents a valid classification method. The valid values are as follows:
  • DefinedInterval—Defined Interval
  • EqualInterval—Equal Interval
  • GeometricInterval—Geometric Interval
  • ManualInterval—Manual Interval
  • NaturalBreaks—Natural Breaks (Jenks)
  • Quantile—Quantile
  • StandardDeviation—Standard Deviation
String
colorRamp
Provides access to the ColorRamp object.
ColorRamp
deviationInterval
A double that represents a valid deviation interval that is only available if classificationMethod is set to StandardDeviation. Valid values are 1.0, 0.5, 0.333, and 0.25. These are the same options available in the application.
Double
intervalSize
A double that represents an interval size that is only available if classificationMethod is set to DefinedInterval.
Double
lowerBound
A double that represents the minimum value of the symbolized classificationField to be displayed.
Remarque :
The value of the lowerBound should only be set to a value within the range of the first class break, otherwise it will fail. The maximum value gets modified in the last class break by changing the upperBound property.
Double
normalizationField
A string that represents a valid layer field name that is used for normalization.
String
normalizationType
A specific string that represents a valid normalization key word. For example, to clear the normalization, try gradColors.renderer.nomalizationType = "<None>".
  • <None>—No normalization
  • <percentage of total>—Percentage of total
  • <log>—Log
String
type
(Lecture seule)
Returns a string that represents the renderer type.
String
Exemple de code
GraduatedColorsRenderer example 1
The following script first tests if the layer's symbology supports a renderer property and then confirms if the renderer is a SimpleSymbolRenderer. Next it changes the renderer to a GraduatedColorsRenderer and it changes the classificationField and breakCount. Finally, it changes ColorRamp to a color ramp named Cyan to Purple.
import arcpy, os, sys
relpath = os.path.dirname(sys.argv[0])
p = arcpy.mp.ArcGISProject(relpath + r'\\GraduatedColors.aprx')
m = p.listMaps('Layers')[0]
l = m.listLayers('State*')[0]
sym = l.symbology
if hasattr(sym, 'renderer'):
  if sym.renderer.type == 'SimpleRenderer':
    sym.updateRenderer('GraduatedColorsRenderer')
    sym.renderer.classificationField = 'Shape_Area'
    sym.renderer.breakCount = 10
    sym.renderer.colorRamp = p.listColorRamps('Cyan to Purple')[0]
    l.symbology = sym
p.saveACopy(relpath + r'\\SavedOutput.aprx')
GraduatedColorsRenderer example 2
The following script modifies the symbology of a polygon layer that uses a graduate color renderer. It sets the classificationField and breakCount and iterates through each class break and modifies the upperBound, label, description, and symbol properties such as color, outlineColor, and size. The labels for each break are formatted to include thousands separators. The fill color graduates from red to blue, and the outline color goes from blue to red and increases in size with each break.
# -*- coding: utf-8 -*-
import arcpy, os, sys, locale
p = arcpy.mp.ArcGISProject(relpath + r"\\GraduatedColors.aprx")
m = p.listMaps("Layers")[0]
l = m.listLayers("Natural*")[0]
sym = l.symbology
sym.renderer.classificationField = "Shape_Area"
sym.renderer.breakCount = 7
breakVal = 100000000000
cv = 0
lw = 1
for brk in sym.renderer.classBreaks:
  brk.upperBound = breakVal
  brk.label = "\u2264" + str(locale.format("%d", breakVal, grouping=True))
  brk.description = "Description " + str(cv)
  brk.symbol.color = {'HSV' : [cv, 100, 100, 100]}
  brk.symbol.outlineColor = {'HSV' : [240-cv, 100, 100, 100]}
  brk.symbol.size = lw
  breakVal +=100000000000
  cv += 40
  lw += 0.5
l.symbology = sym
GraduatedColorsRenderer example 3
The following script modifies the lowerBound and upperBound property values for the renderer's symbolized classificationField. It also uses Python CIM access to display the out of range classificationField values using a default symbol that is automatically generated.
p = arcpy.mp.ArcGISProject('current')
m = p.listMaps('LowerBoundResult')[0]
l = m.listLayers()[0]
if hasattr(l.symbology, 'renderer'):
  if l.symbology.renderer.type == 'GraduatedColorsRenderer':
    sym = l.symbology
    #Set lowerBound set on Renderer
    sym.renderer.lowerBound = 5
    #Set upperBound set on upper ClassBreak
    sym.renderer.classBreaks[-1].upperBound = 96
    l.symbology = sym
    #Show values out of range using Python CIM Access
    l_cim = l.getDefinition('V3')
    l_cim.renderer.useDefaultSymbol = True
    l_cim.renderer.defaultLabel = "Out of range"
    l.setDefinition(l_cim)
